Simple harmonic motion question
The discussion revolves around a problem related to simple harmonic motion involving a mass-spring system. The scenario describes a 10g mass suspended from a spring, detailing its extension and subsequent displacement from equilibrium.
  • Participants discuss calculating the spring constant using the force due to gravity and the extension of the spring. There are attempts to derive the period of motion and maximum speed based on the spring constant and amplitude.
Some participants have provided hints and guidance on calculating the spring constant and using it to find the period of motion. There is an ongoing exploration of the equations relevant to the motion, with participants questioning their assumptions and the application of formulas.
Participants are navigating the complexities of simple harmonic motion and the relationships between force, mass, and spring characteristics. There is an acknowledgment of the difficulty in understanding the topic as it is new to the original poster.
no1schuifan
A mass of 10g is suspended from a spring of unstreched length 80cm. The extension produced is 1cm. The mass is pulled down a further 0.5cm and then released. Find:
a) the period of motion
b)the maximum speed of the mass
c) the max Ke of the mass
d)the tension in the spring when the mass is o.1cm below the equilibrium position
e) the max potential energy stored by the spring
f) the energy released by the spring when the mass moves from its lowest to the equilibrium position.
Any help of any sort will be greatly appreciated as I've only started studying this topic and finding it hard to understand. Many Thanks.
Use the information given to find the spring constant (hint: spring force = mg when the mass is at equilibrium, which occurs when the extension is 1cm).
Then use the sping constant and the amplitude A= 0.5 cm to find all the answers.
How about you start by calculating the spring constant from the information that was given.
Hint: what is the force that causes the spring to extend?
thanks for you help.
So for the spring constant:
mg=w, 0.01*9.81= 0.0981 which i think is the force extending the spring?
if the spring constant = f/x is so then k = 9.81?
if that's the case then to calculate the period could i use T = 2pi ROOT(m/k)?
Looks good!
for part b am i correct in using this equation: v=wROOT(A^2-x^2) and if so because max speed is reached at the equilibirum position would i take x as 0?
  • · Replies 51 ·
