| Thread Closed |
Simple least squares regression problem. Am I doing anything wrongly? |
Share Thread | Thread Tools |
| May17-09, 02:26 PM | #1 |
Least squares regression of Y on A-D based on sample size of 506
Y = 11.08 - 0.954*A - 0.134*B + 0.255*C - 0.052*D s.errs (0.32) (0.117) (0.043) (0.019) (0.006) R^2 = 0.581 problem A. Test null that coefficient on D is equal to 0 d = coefficient on D null: D ~ N(0, 0.006) Pr(d >= 0.052) = 1 - normalcdf(0.052 / 0.006) = 0 reject problem B. Construct 95% confidence interval for coefficient on D 0.052 +/- 1.96*(0.006 / sqrt(506)) problem C. What is the probability that this interval contains the true population regression coefficient on D? ??? just 95%? ___________ The problem gives a lot of info and I only use very little of it, which leads me to believe I'm doing something wrongly. Am I? Thanks for the help! |
| May17-09, 06:56 PM | #2 |
Looks okay except in part B. The output of the regression is giving you the estimated standard deviation of D, so you don't have to divide by sqrt(506). If you wanted to nitpick you could use the t distribution instead of the normal distribution, but since you have 506 observations it is probably not an issue.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Simple least squares regression problem. Am I doing anything wrongly?
| Least Squares Regression Analysis - No Idea! | Precalculus Mathematics Homework | 1 | ||
| Help me understand Least squares regression | General Engineering | 2 | ||
| Normal assumption with least squares regression | Set Theory, Logic, Probability, Statistics | 3 | ||
| Least squares regression problem | Set Theory, Logic, Probability, Statistics | 1 | ||
| Least-Squares Regression | Set Theory, Logic, Probability, Statistics | 1 | ||
