How Do You Calculate the Inverse Laplace Transform of \( \frac{1}{(s+2)^3} \)?
The discussion revolves around calculating the inverse Laplace transform of the function \( \frac{1}{(s+2)^3} \). Participants are exploring methods to derive the inverse transform, referencing class notes and transformation rules.
  • Participants discuss the absence of the specific transform in standard tables and consider applying the frequency shift rule. There are attempts to relate the problem to known transforms, such as \( \mathcal{L}^{-1}\left[ \frac{1}{s^3} \right] \), and questions arise about the manipulation of expressions derived from these rules.
Some participants have provided guidance on applying the frequency shift rule, while others are attempting to clarify their understanding of the transformations involved. Multiple interpretations of the steps to reach the final expression are being explored, indicating an active discussion without a clear consensus yet.
There is a noted reliance on class notes and tables for reference, which may limit the information available to participants. The discussion also reflects uncertainty about the manipulation of expressions and the application of transformation rules.
tony873004
L-1(1/(s+2)3)
I don't see this one in the table. How do I solve the inverse Laplace transform?
I know from class notes that the answer is (1/2) t2e-2t
But I don't know to get it.
Thanks!
I assume that [tex]\mathcal{L}^{-1}\left[ \frac{1}{s^3} \right][/tex] is in your table?
If so, just begin by applying the frequency shift rule:
[tex]\mathcal{L}^{-1}\left[ f(s+a) \right]=e^{-at}\mathcal{L}^{-1}\left[ f(s) \right][/tex]
ok, thanks. That gives me
[tex]\frac{1}{(e^{-2t}L^{-1}(s))^3}[/tex]
And the table gives for [tex]L^{-1}\frac{1}{s^3}[/tex] as [tex]\frac{t^2}{2}[/tex]
What do I do from here?
How do you get that ugly expression?
You should get
[tex]\mathcal{L}^{-1}\left[ \frac{1}{(s+2)^3} \right]=e^{-2t}\mathcal{L}^{-1}\left[ \frac{1}{s^3} \right][/tex]
