Thread Closed
final velocity of a ball pushed by compressed air..pls. help!!
Share Thread Thread Tools
May18-09, 01:34 PM   #1
Compressed air is used to fire a 1.72 kg ball vertically upward from a 1.50 m long
tube. The air exerts a upward force of 28.7 N on the ball as long as it is in the tube.
With what velocity does the ball leave the top of the tube?
2. Relevant equations
F=ma
V12 = v02+2ad
3. The attempt at a solution
so i used the given mass and force to get an acceleration. then using the acceleration i plugged it in to the second equation assuming vinitial to be zero and my asnwer is coming out wrong can someone point me in the right direction thanx :))
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
May18-09, 01:37 PM   #2
Recognitions:
Homework Helper Homework Help
Resultant force= Upward force-downward force
what's the downward force in this case?
May18-09, 01:40 PM   #3
wld the downward force be the friction..but there is no mention of any friction in the question
May18-09, 02:01 PM   #4
Recognitions:
Quote by brunettegurl View Post
if you throw a ball upwards, it does not continue to go upwards, what makes it fall back to earth? (it has a mass m and is under the influence of gravity g)
May18-09, 02:05 PM   #5
ok but that tells us what happens after it is released they're asking for velocity just before it's released from the cannon/tube
May18-09, 02:08 PM   #6
Recognitions:
When you find the resultant force, you can get the resultant acceleration...
and in the formula [itex]v_1^2=v_0^2+2ad[/itex]
what do you need to find to get the value for v1?
May18-09, 02:17 PM   #7
we have the distance(1.50) and we now have an acceleration but would vinitial still be equal to zero??
May18-09, 02:17 PM   #8
Recognitions:
Yes it would be safe to assume the initial velocity as zero.
May18-09, 02:19 PM   #9
thank you so much :))
Thread Closed
Thread Tools
Similar Threads for: final velocity of a ball pushed by compressed air..pls. help!!
Thread Forum Replies
Finding the velocity of an object being pushed up an angular slope Introductory Physics Homework 7
projectile motion finding initial speed of a ball pushed off a table Advanced Physics Homework 4
velocity of air in compressed air tube Introductory Physics Homework 4
Calculating the final velocity of a compressed-air launched projectile Introductory Physics Homework 4
How to solve for final velocity of object pushed by spring using concept of engergy Introductory Physics Homework 3
