Thread Closed
Boundary layer thickness, accelerating flow.
Share Thread Thread Tools
May19-09, 04:18 PM   #1
Hello,
You've all probably seen the classic Blasius solution concerning the thickness of a boundary over a flat plate. This problem though assumes that the free stream velocity is constant.
http://www.see.ed.ac.uk/~johnc/teach...dboundary.html
I am currently faced with a problem where the free stream velocity is increasing as you go down the plate, so I cannot use the Blasius solutions.
I was wondering if anyone out there knows anything about this subject and if they could reference me to some material concerning this topic.
Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
May20-09, 08:07 AM   #2
Recognitions:
It sounds to me like you have a Falkner-Skan Wedge flow. Basically this is a similarity solution (as the flat plate boundary layer). Similarity is achieved by the variable [tex]\eta = Cyx^a[/tex], which is consistent with a power-law freestream velocity distrubtion:
[tex]U(x) = Kx^m\,\,\,; m=2a+1[/tex]
The exponent m may be termed the power-law parameter. do some blah blah blah, and the common form of the Falkner-Skan equation for similar flows is:
[tex]f''' + ff'' + \beta(1-f'^2) = 0[/tex]
Where
[tex]\beta = \frac{2m}{1+m}[/tex]
The boundary conditions are the same for the flat plate:
[tex]f(0) = f'(0) = 0; f'(\infty) = 1[/tex]
Where the parameter [tex]\beta[/tex] is a measure of the pressure gradient, and is positive for positive for a negative or favorable pressure gradient, and negative for an unfavorable pressure gradient; 0 denotes the flat plate.
I won't type the table out, but you should be able to find a table of solutions online somewhere. Basically they are all non-dimensional, so you'll have to find a reference to dimensionalize them to a real-life problem.
Thread Closed
Thread Tools
Similar Threads for: Boundary layer thickness, accelerating flow.
Thread Forum Replies
Measuring thickness of adhesive layer without damaging it Materials & Chemical Engineering 0
Boundary Layer displacement thickness Mechanical Engineering 1
thickness of oxidation layer on fuel elements. Nuclear Engineering 8
Turbulent Boundary layer thickness on a flat plate Mechanical Engineering 1
