Evaluate the following triple integral
The discussion focuses on evaluating the triple integral I = ∫∫∫_{R} x dv in Cartesian coordinates, where R is defined by the surfaces z=0, y=x^3, y=8, and z=x. The participant has successfully established the limits for z and y but is uncertain about the limits for x. A suggestion is made to first visualize the surfaces using a tool like Mathematica to better understand their intersections before proceeding with the integration.
  • Understanding of triple integrals in calculus
  • Familiarity with Cartesian coordinates and volume elements
  • Knowledge of surface equations such as z=0, y=x^3, and z=x
  • Experience with mathematical visualization tools like Mathematica
  • Learn how to visualize surfaces in Mathematica
  • Study the concept of bounded regions in triple integrals
  • Review the process of determining limits of integration for triple integrals
  • Explore the properties of parabolic surfaces and their intersections
Students and educators in calculus, particularly those focusing on multivariable integration and visualization techniques for understanding geometric regions.
caesius
[tex]I = \int\int\int_{R}x dv[/tex]
in Cartesian coordinates where R is the finite region bounded by the surfaces z=0, y=x^3, y=8, z=x. Sketch the region R. Here dV is the element of volume.
What I'm having trouble with is setting up the limits of integration.
I already have
0 < z < x
x^3 < y < 8
but what about x?
And how do I know that the y and z limits are that way around and not x < z < 0 and 8 < y < x^3 instead?
Those inequalities do NOT describe a bounded region. Aren't there additonal restrictions?
Hello Caesius.
May I make a suggestion I think would be helpful to you?
Suppose all you had to do was to plot the surfaces. Never mind (for now) the integration. Could you do that, nicely? The surface z=0 is just the x-y plane right. The surface y=x^3 is a paraboloid sheet, and z=x is a diagonal flat sheet. Suppose that was the only assignment, draw these three surfaces together, transparently so you could see where they intersect, and do it nicely. Then study them, closely, rotate the figure around interactively (you can do that in Mathematica), note the intersections, then go through the algebra proving your observations, then come back and answer your question. :)
  • · Replies 19 ·
  • · Replies 21 ·
