Electromagnet Materials: Can They Stay Magnetized After Current is Switched Off?
The discussion centers on the properties of ferromagnetic materials within a solenoid and their ability to retain magnetization after current is switched off. Participants confirm that permanent magnets are created through a process that allows ferromagnetic substances to maintain a magnetic field due to hysteresis. The conversation highlights that while energy can be stored in an inductor as magnetic energy, it does not return to the battery when the current is turned off, thus complicating the idea of deriving additional energy from the system.
  • Understanding of ferromagnetic materials and hysteresis
  • Knowledge of solenoid operation and magnetic fields
  • Familiarity with inductors and energy storage in magnetic fields
  • Basic principles of energy conservation in electrical systems
  • Research the properties of ferromagnetic materials and their applications in electromagnetism
  • Study the concept of hysteresis in magnetic materials
  • Explore the design and function of inductors in electrical circuits
  • Investigate energy conservation principles in electromagnetic systems
Electrical engineers, physicists, and anyone interested in the principles of electromagnetism and energy storage in magnetic systems.
jonnyk
Hi everyone,
Is there a material which, inside a solenoid, immediately or in a very short period of time gets magnetized as current is switched on and then stays magnetized for a while if the current is switched off? For if this were true then this would mean we could derive more energy out of the system as we put in. We magnetize the material, switch off the current then use that magnet to attract magntic material to it and derive energy from it. Then as the material is demagnetized after some time we can with much less energy remove the materials which were initally attracted to the temporary magnet. Then repeat the process. Wherein lies the problem?
jonnyk said:
… switch off the current then use that magnet to attract magntic material to it …
but wouldn't the presence of that magnetic material resist the current, so that it magnetised the magnet less in the first place, thereby losing energy?
Permanent magnets are made by the process you describe. Every ferromagnetic substance will retain magnetic field due to hysteresis. Now you say we take an inductor put in magnetic energy, switch of the current. Now when you are putting in magnetic energy[1/2Li^2] this energy is not being given back to the battery rather it stays in the inductor and this is the enregy that is being used to attract magnetic materials.
10K
  • · Replies 42 ·
  • · Replies 16 ·
  • · Replies 22 ·
  • · Replies 27 ·
