Thread Closed
Modal analysis of gunshot
Share Thread Thread Tools
May22-09, 04:13 PM   #1
I am not a weapons designer, this is purely to satisfy my own curiosity :)
I would like to simulate a gun shot in a rifle barrel and determine the mode and freq. of vibration using a FE program (Code_Aster if anyone is interested), but I don't really know what transient load to apply.
What components go into making the barrel vibrate? Shape of course, boundry cond. i.e. barrel to receiver connection etc. - but how would you describe the discharge of a round?
Thanks in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
May26-09, 08:07 AM   #2
Recognitions:
Ah, I JUST ran through a similar tutorial of this for the new version of ANSYS. Anyways, I'm going to assume that you are trying to model some sort of automatic gun that can cycle enough times such that resonance could come into play.
Regardless, here's what you kind of do. You'll need to do a full fluid-structure interaction problem. You'll have to either use a combusion model, or a source term to model the bullet (it'll be MUCH MUCH easier than actually modeling the bullet). From there, you do a multiphysics run where you're sending pressures, temperatures, and forces to the structural analysis and getting back displacements and temperatures.
From this, you can do a pre-stressed modal analysis and obtain natural frequencies and modes. At this point you can determine which modes may be of interest. You have a definite applied force, so you can then know which modes need to be payed attention to.
May26-09, 10:14 AM   #3
Recognitions:
How do you describe the discharge? I would venture a guess that it's probably broadband noise. I can't imagine there being any kind of dominating components to the signal.
May26-09, 12:25 PM   #4
Recognitions:
In the example that I did, they simply added mass to the domain as a source term, using a step function. We're probably still a little way off to be able to successfully model a gunshot in every way; the idea is to simply get in the ballpark.
p.s. The particular test I ran through included a muzzle brake at the end of the barrel which made some pretty cool pictures.
May27-09, 03:35 AM   #5
I may be in over my head here, but I would love to skip the combustion step and see if theres a predefined way of applying the mechanical forces to the barrel - what peaked my interest, was the fact that when you add a sound suppressor to a bolt action rifle (not automatic), you will have to re-sight it to accommodate for the new resonate frequency.
I know I'm just barely scraping the surface of the subject here :)
Minger: If you ever in any way publish anything about that experiment, I would love to see it - sounds very cool
May27-09, 06:38 AM   #6
Recognitions:
So you just want a modal analysis of the barrel? Your original post made it appear that you were looking at the gun shot itself.
Where did you hear this? I am interested in this. Knowing what I know of modal testing, I can't see how this would be an influencing factor over other things like say decreased muzzle velocity.
May27-09, 07:43 AM   #7
Recognitions:
No no, this isn't an experiment that we're doing, rather just a tutorial that I went through getting an introduction to the new multiphysics setup with ANSYS.
As Fred said, doing a simple modal analysis may be enough for you. However, you mentioned transient analysis as well, which isn't really needed for a basic modal analysis.
Now having the actual applied loads can be nice. For example, you may think you're operating right on a natural frequency, however if the applied load is something which cannot excite the resonance then....eh.
May27-09, 11:54 PM   #8
Quote by FredGarvin View Post
It is of that principle a barrel tuner works i believe.
Here is some more info that might help you understand what I want to achieve.
http://www.varmintal.com/atune.htm
Thanks for the input so far.
May28-09, 12:18 AM   #9
Compressed Potassium rounds would come closer to the need to bypass combustion but the mass of the round must be increased for the reduced propulsion.
Thread Closed
Thread Tools
Similar Threads for: Modal analysis of gunshot
Thread Forum Replies
modal analysis for a CANTILEVER BEAM Mechanical Engineering 8
Unconstrained Modal Analysis Mechanical Engineering 16
Experimental Modal Analysis Mechanical Engineering 6
More experimental modal analysis Mechanical Engineering 1
Modal Analysis for CE Structures Engineering Systems & Design 0
