Thread Closed
Pipe diameter expansion due to temperature increase
Share Thread Thread Tools
May23-09, 06:47 PM   #1
Hi
Firstly, this is not a homework problem. It's regarding some flow experimental results I have and to understand the results further I am trying to identify possible reasons for the patterns I see. I don't have expertise in thermodynamics hence finding the following problem a bit puzzling. Any help and pointers would be most appreciated.
I have a 60mm OD stainless steel pipe with a wall thickness of 2.5mm I'd like to calculate the increase in both these values as the temperature of water within the pipe increases by 10 deg C. The straight length of the pipe is 4m and it is part of a complicated flow loop so therefore some approximations will need to be made.
How would I go about calculating the increase in the pipe OD and wall thickness as a result this change in temperature? Thanks in advance for your help!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
May23-09, 10:39 PM   #2
Mentor
It is a straightforward calculation multiplying coefficent of thermal expansion by length (of whatever dimension) and temperature change. Give it a try and we'll check your answers...
May24-09, 09:56 PM   #3
Quote by russ_watters View Post
Thanks for your reply! Why should the length of the pipe matter when I am after the expansion in diameter of the pipe? Did you mean diameter instead of length? Puzzled but I'll have a go assuming that you meant to say diameter. Forgive me for being dim! :(
thermal expansion=6.5e-6 (for stainless steel)
temp change= 50F
D=60mm (0.197ft)
So
expansion= 6.5e-6 x 0.197 x 50= 0.06ft ~ 18mm?
That sounds horribly wrong. I think I've misunderstood what you've said. Any help will be much appreciated!
P.S: Could you recommend a reputable book which has changes in pipe diameter as a result of varying temperature?
May25-09, 09:33 AM   #4
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by doop4 View Post
The diameter is also a length (as is the radius, wall thickness, etc.). They all have units of distance, and they'll all expand linearly with temperature if unconstrained. It's just a confusing part of the terminology that the word is the same as the word that describes the distance of the longest extent of the pipe (the pipe length).
Whoa, check your calculations. How can multiplying a number in the parts per million by ten give you 0.06?
It's not a book, but this might get you started.
Thread Closed
Tags
diameter, expansion, pipe, temperature
Thread Tools
Similar Threads for: Pipe diameter expansion due to temperature increase
Thread Forum Replies
Fluid Mechanic help- Find the acceleration rate of a pipe that decreases in diameter Engineering, Comp Sci, & Technology Homework 1
Diameter diff between flow pipe and component connector General Engineering 3
Flow through a pipe along a reduced diameter General Engineering 1
f frequency of small diameter organ pipe Introductory Physics Homework 5
thermal expansion of diameter of pipe filled with water Introductory Physics Homework 8
