What is the sign of the integral for the function y=log_{10}x from x=2 to x=4?
  • Thread starter Thread starter Mentallic
    Integral Sign
The discussion revolves around evaluating the integral of the function \( y = \log_{10} x \) from \( x = 2 \) to \( x = 4 \). Participants are exploring the implications of the integral's value and the properties of logarithmic functions.
  • Participants discuss the use of the change of base formula for logarithms and the integration of logarithmic functions. There is confusion regarding the negative value obtained from the integral despite the function being positive over the interval. Questions arise about the legitimacy of the negative result and the methods used for integration, particularly integration by parts.
Some participants have offered insights into the integration process, including the application of integration by parts. There is ongoing exploration of the techniques involved and the implications of the results, with no clear consensus on the resolution of the negative value issue.
Participants note that the technique of integration by parts has not been covered in class, leading to uncertainty about the expectations for the assignment. This context may influence their understanding and approach to the problem.
Mentallic
Find
[tex]\int_2^4{log_{10}xdx[/tex]
Use the change of base formula
[tex]log_ba=\frac{log_ca}{log_cb}[/tex]
Using the formula:
[tex]\frac{1}{ln10}\int_2^4lnxdx[/tex]
[tex]=\frac{1}{ln10}[\frac{1}{x}]_2^4[/tex]
[tex]=\frac{1}{ln10}(\frac{1}{4}-\frac{1}{2})[/tex]
[tex]=\frac{-1}{4ln10} \approx -0.1086[/tex]
What my problem is, is that the integral is giving a negative value, but the function of [itex]y=log_{10}x[/itex] is positive for [itex]2\leq x\leq 4[/itex].
So is it that I've made a mistake in calculating this integral, or is the negative value I'm getting legitimate? At this point I would need to reconsider when the integral is ever negative.
[tex]\int ln(x)dx = xln(x) - x[/tex]
Mentallic said:
Find
Using the formula:
What've you done here? You seem to have differentiated instead of integrated. As Random Variable mentions above, the 'trick' to integrating the logarithm function is to write it as 1.ln(x) and use parts.
Oh hehe, oops xD
Uhh... I still don't understand how you obtained that result Random Variable. Can you guys please explain this
a little more?
Mentallic said:
Can you guys please explain this a little more?
You can write ln(x) as 1.ln(x), to which you can then apply integration by parts. Let u=ln(x), dv=1dx, which will give du=1/x dx, v=x. Then, recall that
[tex]\int u dv=uv-\int v du\Rightarrow\int \ln x dx=x\ln x-\int x\frac{1}{x} dx = x\ln x - x (+C)\,.[/tex]
This has never been done in class before. Maybe we were meant to experiment or just know this result by natural instinct? :smile: Thanks.
Do you mean that this integral hasn't been done in class, or the technique of integration by parts hasn't been done in class?
Integration by parts. And this integral hasn't been done either or else it wouldn't make sense for the teacher to throw it in an assignment soon after showing us how to solve it (which would mean she would probably have taught us integration by parts at that point :-p).
  • · Replies 21 ·
