Finding the Work Done in a Monatomic Ideal Gas Process
The forum discussion centers on calculating the work done in a reversible cycle involving 1.00 mole of a monatomic ideal gas, as outlined in "Fundamentals of Physics 8th Edition." Key calculations include determining the pressure at various points using the equation PiVi^(Gamma)=PfVf^(Gamma) and calculating work using W=P(delta)V. The discussion highlights the importance of integrating to find the area under the curve for non-rectangular processes, particularly in adiabatic expansions, and emphasizes the need to apply the correct thermodynamic equations, such as W = -ΔU = -nCvΔT, for accurate results.
  • Understanding of thermodynamic principles, specifically the first law of thermodynamics.
  • Familiarity with the ideal gas law and its applications.
  • Knowledge of adiabatic processes and the concept of heat transfer in thermodynamics.
  • Proficiency in calculus for integrating to find work done in non-linear processes.
  • Study the derivation and application of the first law of thermodynamics in various processes.
  • Learn about the integration techniques for calculating work done in non-linear thermodynamic processes.
  • Explore the properties of monatomic ideal gases and their specific heat capacities.
  • Investigate the implications of adiabatic processes on temperature and pressure changes in gases.
Students of physics, particularly those studying thermodynamics, engineers working with gas systems, and anyone involved in energy transfer calculations in ideal gas processes.
Poulsen8r
Hi, this question is from Fundamentals of Physics 8th Edition:
Figure 20-27 shows a reversible cycle through which 1.00 mole of a monatomic ideal gas is taken. Process bc is an adiabatic expansion, with pb = 5.20 atm and Vb = 4.80 x 10-3 m3. For the cycle, find (a) the energy added to the gas as heat, (b) the energy leaving the gas as heat, (c) the net work done by the gas, and (d) the efficiency of the cycle.
(Figure is Attached)
W=P(delta)V
PV=nRT
PV^(Gamma)=nRTV^(Gamma-1)
(Delta)U=Q-W
Q=nCp(Delta)T
(Gamma)= 1.67 for monoatomic gas
Eint=(3/2)nRT
This may look a little weird because of the subscript and powers but i'll give it a go:
Calculating Pressure at (a) and (c):
5.2689e5*4.8e-3=Pf*38.4e-3
Pf=1.6352e4 Pascals
Calculating Work from c to a:
W=P(delta)V
=1.6352e4*(38.4-4.8)e-3
=549.4272J
I believe this is correct...
Calculating temperature at (b) and (c):
T=(PV^(Gamma))/(nRV^(Gamma-1))
Tb=((5.2689e5)*(4.8e-3)^1.67)/(1*8.314*(4.8e-3)^(-0.67))
=304.1944K
Tc=((1.6352e4)*(38.4e-3)^1.67)/(1*8.314*(38.4e-3)^(-0.67))
=75.5233K
Calculating (Delta)Eint for process b to c:
(Delta)Eint=nRTf-nRTi
=nRTc-nRTb
=(1*8.324*75.5233)-(1*8.314*304.1944)
=-2851.757J --> I think this is where the problem lies.
Calculating work for process b to c:
(Delta)Eint=Q-W, as it is adiabatic Q=0 therefore (Delta)Eint=-W.
W=2851.757J
As there is no work for the process a to b, this means that the net work done on the system is 3401.18J... Which is incorrect... I don't know the solution but i know that that answer is wrong... I tried a few other methods than the one above but i get the same answer and i am going crazy and in circles...
W=P(delta)V
=549.4272J
You can't do it this way. You have to integrate to find the area under the curve from c to a. It is not a rectangle.
Use:
[tex]TV^{\gamma - 1} = K[/tex] to find the change in temperature from c to a. Since there is no added heat, you know that [itex]W = -\Delta U = -nCv\Delta T[/itex]
AM
Use:
AM
But why is the work done from c to a not a rectangle? i mean Work is the area under the graph which for the line c to a is a rectangle. And how can we apply the Constant volume formulas when its not at a constant volume? Also how do we know there's no added heat?
