Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Cut of euations in Latex Share It Thread Tools Search this Thread image
Old May24-09, 08:03 AM                  #1
ladil123
ladil123 is Offline:
Hello!
I got a very long equation that I´m writing in Latex, it is so long that the equation reference can´t fit on the same line.
How do I write to cut the equation so it continues on the next line?
Thanks
Old May24-09, 08:05 AM                  #2
cristo
PF Mentor
cristo is Offline:
Re: Cut of euations in Latex
Use eqnarray.
Old May25-09, 06:46 PM                  #3
las3rjock
las3rjock is Offline:
AMS-LaTeX provides a number of nice multi-line equation environments that are preferrable to eqnarray. I generally use the split environment for long single equations and the align environment for multiple equations. See the Short Math Guide for LaTeX for more information.
Old May26-09, 09:16 AM                  #4
minger
minger is Offline:
Recognitions:
Like lars, I prefer to use the split environment. Using it, it looks something like this
Code:
\begin{equation}
\label{whateverequation}
\begin{split}
x &= start of long equation \\
& second half of long equation
\end{split}
\end{equation}
The two backslashes indicate the end of the line, and the ampersands on each line are aligned underneath each other.
Old Jun7-09, 11:10 AM                  #5
statdad
statdad is Offline:
Recognitions:
Homework Helper Homework Helper
The use of eqnarray is no longer suggested, since the spacing leaves much to be desired. as las3rjock noted, there are much better options available.
One more note: this link is a little dated, but the advice found there is good.
http://www.math.uiuc.edu/~hildebr/tex/displays.html
Old Jun8-09, 07:07 AM                  #6
ladil123
Thanks for the help!
I got a follow up question..
If I have "\left(" command on the first line of the equation and the closing "\right)" command on the second line it wont work!
Any tips on how to make it work?
Old Jun8-09, 07:35 AM                  #7
fatra2
fatra2 is Offline:
Could you be more precise in what wont work???
If you have a one line equation that you break at some point, why do you use \left( instead of just (???
I only use the \left( when I have multi line math environment, like a matrix.
Cheers
Old Jun8-09, 08:48 AM                  #8
ladil123
Ok,
My equation has one breaking point. At the first line i got the "\left[" command
and then that line is cut off with \\
Then on the second line I got "\right]".
Then when I should quick build my pdf file I get an error message:
"Missing \right inserted"
below is my input
\begin{align}
w_{h}^{''}(x) & =2 \lambda^{2} \left[ cosh \lambda x (E cos \\
\lambda x - D sin \lambda x ) + sinh \lambda x (B cos \lambda x - A sin \lambda x )\right] \label{winkler_homo8910} \\
\end{align}
I hope I made it more clear ?
Old Jun8-09, 08:52 AM                  #9
minger
minger is Offline:
Recognitions:
There was JUST a post that addressed this. Basically each individual line in latex needs both a left and a right. In order to resolve this with multi-line equations, you use the dummy \left. and \right. constructs. Basically these act as ghost braces to end the current one.
Example:
Code:
\begin{equation}
\label
\begin{split}
x =& \left[ the start of the equation \right. \\
\left. &second half of the equation \right]
\end{split}
\end{equation}
image image
Reply
Thread Tools
Similar Threads for: Cut of euations in Latex
Thread Thread Starter Forum Replies Last Post
LaTeX Kreizhn Programming & Comp Sci 3 Apr17-08 12:32 AM
LaTeX for the Mac cepheid Computing & Technology 3 Sep5-07 06:30 AM
LaTeX dx Forum Feedback & Announcements 8 Nov14-05 12:50 AM
LaTeX dekoi Forum Feedback & Announcements 1 Nov13-05 09:01 AM
LaTex uraknai Computing & Technology 4 Jan22-05 03:59 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
