Thread Closed
Model Rocket Design
Share Thread Thread Tools
May25-09, 03:29 PM   #1
Model Rocket Design
Hello,
This summer I would be interested in designing my own model rocket. I do not have a lot of aerospace/aerodynamics (read the NASA (http://www.grc.nasa.gov/WWW/k-12/airplane/)) knowledge but I do have a good grasp of math and physics.
I would like to use a A or B model rocket engine and get then maximum altitude out of the rocket. In the end maybe try to beat the record but for now just want to get started with a design and learning how this works.
So how would I start?
I got a list of questions(list of how to start) that I will research and try to answer
Am I missing any important things?
-best weight and dimensions
nose cone(size, shape)
body tube(size, shape)
fins(size, shape, locationg on body tube, number)
*idea* with the right spin would having curved fins help?
centering tube(distance out of the body tube)
center of gravity(position)
center of pressure(position)
***CP is behind the CG***
should the rocket have transition from thin at top to thick at the bottom?
Also would this be allowed at a competition?
rocket with no parachute?
push rocket with ejection charge and eject engine out?(my own idea, not sure if it would help a lot)
Thank You
Art
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
May31-09, 04:48 PM   #2
Hi,
Well first if you want more advice go to tripoli (Internatinal amateur rocket group):
http://www.tripoli.org
I suppose your in USA so you should watch the NAR site :
http://www.nar.org
The best weight would be 0.000000001 pound :)
An a quick and easy way to calculate the CG-CP is Winroc:
http://www.drmoore.org/winroc.htm
Thread Closed
Tags
design, rocket, rocketry
Thread Tools
Similar Threads for: Model Rocket Design
Thread Forum Replies
Would this design work? (rocket) Mechanical Engineering 10
I was to design my own rocket. General Physics 11
Model Rocket design:FYP: help? Mechanical Engineering 8
Rocket Engine Design Mechanical Engineering 17
model rocket Introductory Physics Homework 10
