There's a constant factor which depends on what you mean by "prime factor". From your numbers I take it you're counting indistinct prime factors, in which case the constant is 1.03465388....
It predicts an average of (2.97, 3.25, 3.48) versus your calculated (2.87, 3.19, 3.43). It will get more accurate as the numbers involved increase. For example, I calculated
A071811(9) = 4044220058, which compares favorably to the predicted 4065910904.
It should be possible to work out a second-order term (which would be negative) to correct for the presence of small numbers, if you care about that kind of precision.
