Thread Closed
Uncertainty propagation visible light spectrum
Share Thread Thread Tools
May27-09, 02:47 PM   #1
I have conducted an experiment which attempts to calculate the range of the visible light spectrum. Basically white light was shined through a diffraction grating (300 lines/mm) and diffraction theory is applied to calculate the wavelength.
So, here are the variables:
[tex]d=\frac{1}{300000}[/tex]
[tex]l=0.20[/tex]
[tex]\Delta l=0.001[/tex]
[tex]y=0.043[/tex]
[tex]\Delta y=0.005[/tex]
2. Relevant equations
[tex]\sin\alpha=\frac{\lambda}{d}[/tex]
[tex]\tan\alpha=\frac{y}{l}[/tex]
3. The attempt at a solution
I combined these equations to end up with:
[tex]\lambda=d\times\sin\left(\arctan\left(\frac{y}{l}\right)\right)[/tex]
The problem is that I don't know how to estimate an uncertainty for this equation. I know that for simple equations like [tex]y=q\times r[/tex] the uncertainty is [tex]\Delta y=\left(\frac{\Delta q}{q}+\frac{\Delta r}{r}\right)\times y[/tex]. Unfortunately I don't know how to apply this to a more complex equation. If anyone could lead me in the right direction as to an equation which would give the uncertainty for [tex]\lambda=d\times\sin\left(\arctan\left(\frac{y}{l}\right)\right)[/tex], it would be greatly appreciated.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
May27-09, 05:29 PM   #2
Mentor
It can be done using calculus, if you've had calculus. But first I would get rid of the trig functions.
What's an equivalent expression for sin(arctan(x)) ?
May28-09, 01:14 AM   #3
[tex]\frac{x}{x^{2}+1}[/tex]
Substituting [tex]\frac{y}{l}[/tex] for [tex]x[/tex] gives:
[tex]\frac{\frac{y}{\left|y\right|}\times l}{\sqrt{y^{2}+l^{2}}}[/tex]
I hadn't thought of doing this, so it seems to be a step in the right direction. I have done limited calculus, I'm just finishing the first year of IB Math HL so we're starting on integration right now. I looked briefly at the wikipedia page for error propagation and didn't really understand it.
May28-09, 02:03 AM   #4
Recognitions:
Homework Helper Homework Help
Hmm... yeah, Wikipedia is being ridiculously detailed about this.
FYI, here's the usual case: if you have a function [tex]f(x, y, z)[/tex] and the uncertainties in the arguments are [tex]\delta x[/tex], [tex]\delta y[/tex], and [tex]\delta z[/tex], then the uncertainty in [tex]f[/tex] is
[tex]\delta f = \sqrt{\left(\frac{\partial f}{\partial x}\delta x\right)^2 + \left(\frac{\partial f}{\partial y}\delta y\right)^2 + \left(\frac{\partial f}{\partial z}\delta z\right)^2}[/tex]
Of course, there are some conditions on that formula, i.e. small, independent (uncorrelated) uncertainties and Gaussian distributions, but probably 99% of the time that formula is good enough.
May28-09, 03:34 AM   #5
OK, thanks for the help so far. I applied the above formula to my equation and received the following result:
[tex]\delta f = \sqrt{{\delta l}^{2}\,{\left( -\frac{d\,\left| l\right| \,y}{{l}^{2}\,\sqrt{{y}^{2}+{l}^{2}}}+\frac{d\,y}{\left| l\right| \,\sqrt{{y}^{2}+{l}^{2}}}-\frac{d\,\left| l\right| \,y}{{\left( {y}^{2}+{l}^{2}\right) }^{\frac{3}{2}}}\right) }^{2}+{\delta y}^{2}\,{\left( \frac{d\,\left| l\right| }{l\,\sqrt{{y}^{2}+{l}^{2}}}-\frac{d\,\left| l\right| \,{y}^{2}}{l\,{\left( {y}^{2}+{l}^{2}\right) }^{\frac{3}{2}}}\right) }^{2}}[/tex]
Substituting with the variables in my first post returns the result:
[tex]\delta f = 7.79\times 10^{-8}[/tex]
Which is exactly what I received when I tried using an online uncertainty calculator! Thank you so much!
Thread Closed
Tags
light, uncertainty, wavelength
Thread Tools
Similar Threads for: Uncertainty propagation visible light spectrum
Thread Forum Replies
Burning Elements - Visible Light Spectrum General Physics 2
Shifting from IR to visible spectrum - Help pls! Atomic, Solid State, Comp. Physics 6
uncertainty propagation Introductory Physics Homework 3
Why can visible light pass among glass? Why glass is is transparent to visible light? General Physics 1
visible spectrum General Physics 17
