Find \frac{1}{i+z} as a Power Series in z | Learn to Use Taylor Series
The discussion revolves around finding the expression \(\frac{1}{i+z}\) as a power series in \(z\). Participants are exploring the use of Taylor series and other methods to achieve this expansion.
  • Mixed
  • Participants discuss using Taylor series, derivatives, and alternative methods like long division and geometric series to find the power series. There is uncertainty about the correct point of expansion and the nature of derivatives involved.
Some participants have offered guidance on using geometric series and long division as potential methods. There is an ongoing exploration of the correct approach to take, with various interpretations of the problem being considered.
There is mention of the singularity at \(z=i\) and the implications it has on the expansion. Participants are also questioning the appropriateness of expanding around different points.
aks_sky
I need to find [tex]\frac{1}{i+z}[/tex] as a power series in z.
I want to know if am doing this right.
If i use the taylor series here by doing
[tex] f(z) = z^i[/tex]
[tex] f'(z) = i z^{-1} z^i[/tex]
[tex] f''(z) = i (i-1) z^{-2} z^i[/tex]
This taylor series is just for z= i +1, but i tried using it for my problem but i don't seem to get the right answer.
this is the taylor series that i should be using but how do i find f(i) here?
[tex] <br /> f(z) = f(i) + f'(i) (z-i) + f''(i) (z-i)^2 + \cdots<br /> [/tex]cheers
If you needed to find the power series for 1/(1 - x), you could do it by getting the various derivatives, but an easier way would be just to do the long division. I would give that a shot first with the function you have. The thing about a power series is that it is unique, so however you get it, that's the one.
oh yup that's cool.. i just had another question.. will i be finding the derivative of f(z) or f(i) for the taylor polynomial?
I'm not sure you are getting it. f(i) is a constant. And you don't have to take any derivatives. As Mark44 said, you can expand 1/(i+z) in a power series without taking any derivatives. Write it as (1/i)*(1/(1-iz)). Now expand 1/(1-iz) as a geometric series. 1/(1-x)=1+x+x^2+x^3+... Does that ring a bell?
aks_sky said:
power series in z.
You can do any of the short cuts given already (long division / geometric series), but if you want to grind the Taylor expansion machinery, then you are doing two things wrong.
I read the quotation above to mean an expansion about z=0. What you are trying to do is an expansion about z=i. That is mistake number 1. (As an aside, I don't think you can do that because z=i is a singularity and I don't think your power series can be done around a singularity. However, I may not be 100% correct in this)
Your second mistake is that the function f(z) = 1 / (i+z). Why did you use z^i? Take the derivatives of the full f(z) and plug in z=0 the get the series coefficients.
If you use the function as given, and expand around z=0, then you should get the same thing as the short cut methods.
You could also use the fact that the sum of the geometric series
[tex]\sum_{n= 0}^\infty r^n= \frac{1}{1- r}[/tex]
That's similar to Mark44's suggestion.
Oh, and
[tex]\frac{1}{i+ x}= \frac{1}{i(1+ \frac{x}{i})}= -i\frac{1}{1- (-\frac{x}{i})}[/tex]
sweet as.. got it.. cheers
  • · Replies 17 ·
