Can Alnico Magnets Undergo Pole Reversal with a Magnetizer?
  • Context: Undergrad
  • Thread starter Thread starter zydubion1
    Magnets Pole
Alnico magnets can undergo pole reversal when subjected to a magnetizing machine, specifically designed for magnetizing and de-magnetizing. A cylindrical alnico magnet measuring 1/2 inch in diameter and 1 inch long can be re-magnetized to achieve a magnetic field strength of up to 1.6 Tesla. To accomplish this, a DC magnet with a configuration of 460 turns at 70 amps is required, factoring in the permeability of free space. For practical applications, small table-top magnetizing units are available for home experiments.
  • Understanding of Alnico magnet properties and specifications
  • Knowledge of magnetic field strength calculations
  • Familiarity with magnetizing machines and their functionalities
  • Basic electrical engineering concepts, including amp turns and pulse duration
  • Research small table-top magnetizing machines for home use
  • Learn about the construction and operation of capacitor banks for magnetization
  • Investigate the effects of pulse length on eddy currents in magnetic materials
  • Explore the properties and applications of different Alnico grades
Engineers, hobbyists, and researchers interested in magnet technology, particularly those working with Alnico magnets and magnetization techniques.
zydubion1
An cylindrical alnico magnet is 1/2 inch diameter and 1 inch long. It is magnetized through its length. I realize that this magnet can be magnitized over and over again. But can the poles be reversed if subjected to a machine that magnetizes and de-magnitezes magnets? Also, where can one purchase such a machine? What are they called? Are there small table-top units availabe for home experiments?
Suppose you wanted to build a dc magnet that could go to 1.6 Tesla, and re-magnetize your Alnico magnet. Suppose the gap was 0.025 meters, and the remainder of the path was 1 meter in iron ( "C" magnet) with a permeability u of 5000. The total amp turns you will need is
NI = 1.6 x 0.025/u0 + 1.6 x 1.0/u u0 = 32,000 + 260 = 32,260 amp turns, where u0 = permeability of free space ( 4 pi x 10-7 Henrys per meter).
So you will need say 460 turns at 70 amps (peak).
See http://www.gmw.com/electromagnets/dipole/5403/5403_Specs.html
[Edit] Here is a sheet of Alnico properties:
http://www.dextermag.com/uploadedFiles/Alnico_Data_Sheet.pdf
Some Alnico's have a residual magnetization of 1.35 Tesla, so you probably want to push Bmax up to 1.6 Tesla. You can do it with a pulse several seconds long, so you can use an air-cooled magnet much smaller than the one shown in the GMW web page. You can use a capacitor bank to provide the pulse. The voltage required depends on the resistance of the wire coils (e.g., 10 Ga formvar wire), and the pulse length on the RC time constant. If your iron is solid, the pulse length must be long enough for the eddy currents to die out.
10K
  • · Replies 60 ·
  • · Replies 52 ·
9K
10K
  • · Replies 17 ·
