Combining Functions: Explaining Multiplication of F(X) & H(X)
  • Thread starter Thread starter CanadianEh
    Functions
The discussion centers on the analysis of the combined function F(X) * H(X), where F(X) = X and H(X) = COS X. The graph of this multiplication exhibits oscillation due to the cosine function, with no asymptotes present. Key features such as the behavior of the graph when X is positive or negative are highlighted, indicating that the oscillation's magnitude increases as X moves away from zero. The analysis also contrasts this with potential behaviors of addition, subtraction, and division of the two functions.
  • Understanding of basic functions, specifically linear and trigonometric functions.
  • Knowledge of graphing techniques for functions and their transformations.
  • Familiarity with key features of graphs, including domain, range, and intercepts.
  • Concept of periodic functions and their effects on combined function behavior.
  • Explore the properties of the product of functions, specifically focusing on F(X) * H(X).
  • Learn about the graphical representation of combined functions, including oscillation effects.
  • Investigate the implications of division of functions, particularly F(X) / H(X) and its asymptotic behavior.
  • Study the transformations of functions and how they affect the overall graph characteristics.
Students studying calculus, particularly those focusing on function analysis, graphing techniques, and the behavior of combined functions. This discussion is also beneficial for educators seeking to explain the concepts of multiplication and division of functions in a visual context.
CanadianEh
I was giving a graph of a combined function and four different equations and I need to select 2 of the equations and whether the graph shown is of addition, subtraction, multiplication or division. F(X)= X and H(X) = COS X and the combined graph is F(X)*H(X).
I need to justify my answer using key features of the graph as related to the initial functions
My attempt:
I could easily tell in my head that the graph shown on my paper was of X*cosX, but I'm just not sure how to explain it using the key features (domain, range, x and y ints, etc.). Essentially, I have to explain why I chose those two functions and why I chose multiplication.
- The new function is oscillating, which is why cos X is one of the functions.
- There are no asymptotes
What else can I say? Thanks in advance.
Here are some ideas. You didn't say what the other two functions are, which makes it difficult to say why you chose f(x) = x and h(x) = cos x as the two you chose. As far as the arithmetic operation, think about how the graphs of f + h, f - h, fh, and f/h would look, based on the two functions you showed, and the other two that you didn't show.
For f + h you would have a graph that has the same oscillation as cos x, but with a central axis (for lack of a better word) that angles up to the right.
For f - h, which is equal to f + (-h), the graph would be similar to that of f + h, except that instead of adding cos x you would be adding its reflection across the x-axis.
For fh, when x > 0, you are multiplying by increasingly larger values, so you get the oscillation of the cosine factor, but the magnitude of the oscillation increases. When x < 0, this time you are multiplying by numbers that are getting more negative, which has a similar effect on the magnitude of oscillation, but also flips the cosine graph across the x-axis.
For f/h, because you are dividing by something that is periodically zero, there are going to be vertical asymptotes at each odd multiple of pi/2 (i.e., at +/-pi/2, +/-3pi/2, +/-5pi/2, and so on). At all other points you are going to be dividing by numbers in the interval [-1, 1], so there will be points on the graph that are identical to those on the graph of f(x) = x, and some that are identical to those on the graph of y = -x.
That should give you something to think about.
