What Determines the Block's Motion on an Accelerating Wedge?
  • Thread starter Thread starter zeena2009
    Block Wedge
The discussion focuses on the dynamics of a 2kg block resting on a frictionless wedge inclined at 60 degrees, analyzing the effects of varying wedge acceleration. The key conclusion is that when the wedge's acceleration exceeds a specific threshold, the block will slide up the incline, while a lower acceleration will cause the block to slide down. The balance of forces acting on the block, including gravitational and inertial forces, determines its motion relative to the wedge. This scenario parallels the physics of a car navigating a banked curve, where centripetal acceleration plays a crucial role.
  • Understanding of Newton's laws of motion
  • Familiarity with free body diagrams
  • Knowledge of forces acting on inclined planes
  • Basic principles of acceleration and inertia
  • Study the effects of varying angles on inclined plane dynamics
  • Learn about centripetal acceleration in circular motion
  • Explore the concept of equilibrium in physics
  • Investigate frictionless surfaces and their applications in mechanics
This discussion is beneficial for physics students, educators, and anyone interested in understanding the mechanics of motion on inclined planes and the effects of acceleration on objects in motion.
zeena2009
A 2kg block rests on a frictionless wedge that haas 60 degree incline and an acceleraion a to the right such that the mass remains stationary relative to the wedge.
a) determine a?
b) what would happened if the wedge were given an acceleration larger than this value?
c) what would happened if the wedge were given an acceleration smaller than this value?
I got a, it's b and c i didnt get
i think that when you give larger accelertaion, the block would slides up
and smaller, the blick slides down the incline
that's my common sense
however, when i tried to do it mathmatically and algebrically, it didnt make sense.
so please help me ??
Welcome to PF.
Draw a diagram. Consider the interface between the incline and the block.
The inertia of the block will have a force in reaction to the force of the accelerating incline. Viewed in the frame of reference of the incline then the block is subject to the two accelerations - 1 horizontal and the other vertical. You found the answer when they were in balance, but as you note then when the acceleration is greater than equilibrium condition, the component || along the plane will be greater than needed to resist the || component of the vertical gravity.
If you think about it, this is similar to a car on a banked curve. But rather than the incline accelerating, you have the centripetal acceleration from the circular motion.
  • · Replies 37 ·
