Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Set Theory, Logic, Probability, Statistics
Reply
image Help with Shapiro-Wilk Test interpretation. Share It Thread Tools Search this Thread image
Old May30-09, 10:50 AM                  #1
FrostScYthe
FrostScYthe is Offline:
Hi everyone,
I need to make sure that I'm interpreting the Shapiro WIlk test correctly. This is how I'm doing the interpretations:
Set 1
CI = 95%
n = 15
Shapiro W = .92
p = .171
I think this set is distributed normally because p is the probability that it is not normal, so the probability that it isn't normal is 17.1% right?
Set 2
CI = 95%
n = 15
Shapiro W = .95
p = .502
This set is slightly more probable to be not distributed normally because p is 50.2 %
Any help appreciated,
Ed.
Old May30-09, 03:11 PM                  #2
Enuma_Elish
Enuma_Elish is Offline:
Re: Help with Shapiro-Wilk Test interpretation.
Since CI = 95% implies a critical "alpha" value of 5%, the null hypothesis of normality cannot be rejected for either set (at the 5% level of statistical significance).
Old May30-09, 03:28 PM                  #3
FrostScYthe
But I can reject Set 1, if I chose an alpha like 20% right?
Old May31-09, 01:46 PM                  #4
Enuma_Elish
Correct.
Old Jun1-09, 03:38 PM                  #5
FrostScYthe
Looking at this test more carefully. This test is more for testing whether a sample comes from a population that is not normally distributed.
I mean if the p > alpha then you can't reject the probability that it might be Normal (but it is just a probability, it doesn't tell you how probable is it that it is normal?). What is a good test to determine whether a distribution is Normal or not?
Old Jun2-09, 09:49 PM       Last edited by EnumaElish; Jun2-09 at 10:06 PM..            #6
EnumaElish
EnumaElish's Avatar
EnumaElish is Offline:
Recognitions:
Homework Helper Homework Helper
If p > alpha then you can't reject the NULL HYPOTHESIS that THE DISTRIBUTION IS Normal.
When testing a hypothesis you cannot ever accept the null hypothesis, you can either reject, or fail to reject. There is no statistical test that will tell you the distribution is normal; they can only tell whether you can or cannot reject normality. See this paper.
I suggest using tests based on skewness and/or kurtosis; two examples are the Jarque–Bera test and D'Agostino's K-squared test. If you don't need a formal test result, you can also make a Q-Q plot and decide visually.
Old Jun3-09, 07:10 PM                  #7
FrostScYthe
Thank EnumaElish for clarifying that for me :).
image image
Reply
Thread Tools
Similar Threads for: Help with Shapiro-Wilk Test interpretation.
Thread Thread Starter Forum Replies Last Post
Structure and Interpretation Structure and Interpretation of Classical Mechanics navaburo Advanced Physics Learning Materials 1 Jul11-09 10:08 AM
Shapiro time delay? kev Special & General Relativity 42 May12-09 04:44 AM
Shapiro Delay Zman Special & General Relativity 1 Aug7-08 12:39 PM
Integral test, basic comparsion test, limit comparsion test kingwinner Calculus & Beyond 11 Apr6-07 10:01 AM
Shapiro Effect and Gravitational Lensing shrumeo General Astronomy 6 Jun14-04 08:35 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
