Why Use an Integrating Factor in Differential Equations?
  • Thread starter Thread starter transgalactic
    Integration
The discussion focuses on the use of an integrating factor in solving the first-order linear differential equation \(\frac{dp}{dt}+2tp=p+4t-2\). The integrating factor is derived as \(e^{\int (2t-1)dt}=e^{t^2 -t}\), which simplifies the equation. Participants clarify that multiplying the differential equation by the integrating factor allows for the left side to be expressed as the derivative of the product of the integrating factor and the function \(p\). This method is essential for obtaining the solution to the differential equation.
  • Understanding of first-order linear differential equations
  • Familiarity with integrating factors in differential equations
  • Basic knowledge of calculus, specifically integration
  • Ability to manipulate exponential functions
  • Study the derivation and application of integrating factors in differential equations
  • Learn how to solve first-order linear differential equations using integrating factors
  • Explore examples of differential equations that require integrating factors for solutions
  • Investigate the role of exponential functions in differential equations
Students and professionals in mathematics, particularly those studying differential equations, as well as educators seeking to enhance their teaching methods on this topic.
transgalactic
[tex] \frac{dp}{dt}+2tp=p+4t-2[/tex]
[tex] e^{\int (2t-1)dt}=e^{t^2 -t}[/tex]
then we do
[tex] \frac{d}{dt}[e^{t^2 -t}]=...[/tex]
why??
i was told that i will get the original left side of the equation times p.
i didnt get the same resultwhat is the role of integration factor
An integrating factor is a function with which you multiply the differential equation to help facilitate the solving of the differential equation.
There was a similar question here a few days ago, where I did part of the calculation.
https://www.physicsforums.com/showthread.php?t=316907
Check post 4.
  • · Replies 105 ·
13K
