How Do Shock Functions Aid in Solving Differential Equations?
  • Thread starter Thread starter transgalactic
    Method
The discussion focuses on the application of shock functions, specifically U(t)=1, in solving differential equations related to electrical circuits. The equations presented include the homogeneous solution (V_ch)' + (1/RC)V_ch = 0 and the substitution method for finding solutions. The participants clarify the use of exponential functions in the context of linear equations with constant coefficients, emphasizing that the shock function U(t) represents a sudden change in voltage, Vs(t) = V_0 U(t). The conversation highlights the importance of understanding the relationship between the homogeneous solution and the initial conditions provided.
  • Understanding of differential equations, particularly first-order linear equations.
  • Familiarity with electrical circuit concepts, including RC circuits.
  • Knowledge of homogeneous solutions and their derivation.
  • Proficiency in calculus, specifically integration and differentiation of exponential functions.
  • Study the derivation of solutions for first-order linear differential equations.
  • Explore the application of Laplace transforms in solving differential equations.
  • Learn about the characteristics of shock functions in control systems.
  • Investigate the relationship between exponential functions and solutions to differential equations.
Students and professionals in engineering, particularly those focusing on electrical engineering and control systems, as well as anyone interested in the mathematical foundations of differential equations.
transgalactic
U(t)=1
[tex] Vs(t)=V_0 U(t)[/tex]
[tex] (Vc)' + \frac{1}{RC}Vc=\frac{1}{RC}Vc=\frac{1}{RC}V_0[/tex]
[tex] (Vc)' + \frac{1}{RC}Vc(t)=\frac{1}{RC}V_0[/tex]
given:
[tex] Vc(0^+)=0[/tex]
from her i can't under anything regarding the term of use:
homogeneous solution is:
[tex] (V_ch)'+\frac{1}{RC}Vch=0[/tex]
we guess a solution from the form of
[tex] V_ch=Ae^{st}[/tex]
and substitute into the homogeneous equation:
[tex] \int Ae^{st} +\frac{1}{rc}Ae^{st}=0[/tex]
these are only the first two steps but i can't understand why are they doing that
the youtube solution differs a lot
transgalactic said:
U(t)=1
I don't understand this. Did you mean to have those two "=" or is this a typo?
Okay, is this what you meant above?
given:
Well, that's the "associated homogeneous equation", not yet a "solution".
You can rewrite it as [itex]dV_{ch}/V_{ch}= (-1/RC)dt[/itex] and integrate that.
[itex]ln(V_{ch})= -t/RC+ K[/itex] and taking exponentials of both sides, [itex]V_{ch}= K_1e^{t/RC}[/itex] where [itex]K_1= e^K[/itex].
Why an integral? [itex]V_{ch}'[/itex] is the derivative
[tex](Ae^{st})'+ \frac{1}{rc}Ae^{st}= sAe^{st}+ \frac{1}{rc}Ae^{st}= 0[/tex]
so the exponentials cancel leaving s+ 1/rc= 0. s= -1/rc and the solution becomes [itex]Ae^{t/rc} just as before. That method is more often used with higher order differential equations where you cannot integrate as I did above.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> these are only the first two steps but i can't understand why are they doing that<br /> the youtube solution differs a lot<br /> <br /> ?? </div> </div> </blockquote> You can justify that method by arguing that for y(x) something like Ay"+ By'+ Cy= 0, a "linear equation with constant coefficients", in order that y and its derivatives cancel, to give 0, y' and y" must be the same "kind" of function as y. Exponentials do that nicely: the derivative of [itex]e^{ax}[/itex] is [itex]ae^{ax}[/itex], the same exponential multiplied by a.<br /> <br /> But you should be aware this is not based on any idea that a solution MUST be an exponential! For example, The equation y"= 0 has general solution y= Ax+ B and y"+ y= 0 has general solution y= A cos x+ B sin x. Since those solutions are indirectly related to exponentials, "trying" [itex]e^{sx}[/itex] can still lead you to them.[/itex]
U(t) is called the shock function
it equals 1 in this case
Vs=vo*U(t) (Vs the voltage of the source)
does this help ??
