What is the difference between 'so that' and 'such that' in mathematical jargon?
  • Context: Undergrad
  • Thread starter Thread starter lolgarithms
The discussion clarifies the distinctions between the phrases "so that" and "such that" in mathematical contexts. "Such that" is used to describe a condition that is already established, as in "z is a complex number such that Re[z]>0," while "so that" indicates a purpose or intended outcome, exemplified by "Define z so that Re[z]>0." The consensus is that "such that" applies to nouns and describes qualities, whereas "so that" applies to verbs and indicates a means to an end.
  • Understanding of mathematical jargon and notation
  • Familiarity with complex numbers and their properties
  • Basic knowledge of English grammar and syntax
  • Experience in writing mathematical papers or formal documentation
  • Research the formal definitions of "so that" and "such that" in mathematical literature
  • Explore examples of correct usage in mathematical proofs and papers
  • Study the grammatical rules governing conjunctions in English
  • Examine common pitfalls in mathematical writing to avoid ambiguity
Mathematicians, students in mathematics or related fields, and anyone involved in writing or reviewing mathematical papers will benefit from this discussion.
lolgarithms
Have a question about usage of mathematical jargon...
what are the differences between usage of "so that" and "such that"?
"z is a complex number such that Re[z]>0.": correct
"z is a complex number so that Re[z]>0.": wrong
but what about this case:
"Define z so that Re[z]>0"
"Define z such that Re[z]>0"
I really can't embarrass myself when I write mathematical papers. please help.
Mathematics news on Phys.org
Perhaps someone has a more technical answer than this, but...
For me, "such that" means something is already a certain way and you're describing it, whereas so that means that something isn't a certain way already, but you're prescribing it. For instance...
"You have to study *so that* you will pass the test."
"You read a book *such* that it's 20 pages long."
Like, "so that" is a means to an end, and "such that" is just how it is.
I apologize if this isn't right. Somebody will be along to correct me.
In English, the difference between "so that" and "such that" is a much easier one to make, but I'm not sure it carries into the realm of mathematics. "such" is a word derived from "so much". "Such" deals with quantities, whereas "So" deals with qualities.
I looked up "such that" in the Collins concise English dictionary and the definition was:used to express purpose or result."So that",however, was adjacent to "such that" but not in bold type.It seems from this that either usage is correct.When I looked for
"so that" it wasn't entered.Because of the emphasis in the dictionary it seems that "such that" is the preferred usage.I,also,apologise if this isn't right.
"So" means "hence" - there should be a deduction: we choose X so that Y is true.
Or something like that, anyway. 'Such that' can also be used to mean 'satisfying' where it wouldn't be sensible to use 'so that'.
"Define z so that Re[z]>0": correct
"Define z such that Re[z]>0": incorrect
"Suppose there exists a complex number z such that Re[z]>0": correct
"Suppose there exists a complex number z so that Re[z]>0": incorrect
Grammatically, "such that" applies to a noun, "so that" applies to a verb. I believe that is also what Enuma Elish is saying.
im kinda confused because of different explanations
also, you can say "z is defined so that Re[z] > 0"
in other words, "so that" indicates an end, a purpose while such that just describes
does this sum up the correct usage?
Well there does seem to be confusion here and perhaps we are being too fussy.How about an alternative, for example...Z is defined in such a way that etc
"Such" seems to have a quality like a relative pronoun which can be used in combination with "that", working as a conjunction. HallsOfIvy gave the briefest and most useful characterisation. The "such" involved can be an idea having no concrete existence.
  • · Replies 38 ·
