| Thread Closed |
Is SSTAR Program Still Alive? |
Share Thread |
| Jun3-09, 03:22 AM | #1 |
Is the Small, Sealed, Transportable, Autonomous Reactor program at Lawerence Livermore still going? I haven't found any recent updates on it.
http://en.wikipedia.org/wiki/SSTAR It seems to me that a design like this would be ideal for providing power in the 3rd world, since it doesn't have to built onsite or refueled. After 30 years you haul it off and put in a new one. Having local power grids with 100mw plants would avoid a lot of the expense of setting up major power grids we use. It would be almost like how cell phones let the 3rd world leapfrog setting up the communication grids. Even in the US, it might be cheaper for a smaller utility company to buy one SSTAR every year than a 1GW unit every 10, since it would tie up less capital for shorter periods of time. |
| Jun7-09, 07:39 PM | #2 |
| Jun8-09, 04:22 AM | #3 |
I think the Pu-239 gets burned up in situ, so you can't actually crack open the reactor and get enough Pu-239 for a bomb. I've also seen some discussion of using the design for a Thorium reactor. U-233 is much less suitable for weapons than Pu-239.
The high burnup is an essential part of the design, since the reactor is delivered prefueled and runs for 30 years and then is taken down and replaced. That way you don't have nuclear fuel that could be diverted to a weapons reactor. Has anyone ever actually used a power reactor to produce weapons material? The wikipedia article make weapons reactor sound a lot different. http://en.wikipedia.org/wiki/Pu_239 It sound like to have a harvest the Pu-239 frequently before it picks up additional neutrons and you end up with too much Pu-240 etc. |
| Jun8-09, 09:17 AM | #4 |
Recognitions:
Is SSTAR Program Still Alive?If by "power reactor" you mean a typical LWR - light water reactor - then the answer is no - nobody regularly uses LWRs to produce weapons material. However, if you turn the question around and ask, "Has anyone used a weapons production reactor to produce power" - then the answer to that is yes. Years ago, when the USA was still making plutonium at Hanford, one of the reactors, the newest of the Hanford reactors which started operation in the early '60s; was the Hanford "N Reactor". [ Production reactors were named with letters, "B Reactor", "K reactor"....]. The Hanford "N Reactor' was unique in that the plant incorporated an electric power production plant. All other production reactors at Hanford simply dumped their waste heat into the Columbia River. The "N Reactor" used that heat to produce power - and the waste heat from the Rankine cycle was dumped into the Columbia. You are correct that one has to harvest the Plutonium frequently. If your main purpose for the reactor plant is generating electricity - and you have an LWR - then frequent shutdowns in which you have to cool down the reactor, unbolt and remove the head; all to harvest Plutonium is a big job for a task that isn't your primary purpose. It's easier to operate the LWR for a year to 18 months before you have to open it up. On the other hand, if your main job is producing weapons material and you are going to start / stop the reactor anyway - then you may as well add the Rankine cycle to make use of the energy you produce. As I recall, the Hanford "N Reactor" was a 4 Gw(t) reactor and just dumping that much energy as heat would be wasteful. http://www.hanford.gov/?page=345&parent=326 http://en.wikipedia.org/wiki/Hanford_Site The RBMK reactors at Chernobyl were also dual use reactors - they produced weapons material in addition to electric power. Dr. Gregory Greenman Physicist |
| Thread Closed |
Similar discussions for: Is SSTAR Program Still Alive?
| Braid-Matter program still alive and grinding ahead | Beyond the Standard Model | 0 | ||
| Astro simulation program problem - program bugs? | Astrophysics | 4 | ||
| I'm still alive | General Discussion | 9 | ||
| alive and kicking, well alive anyway | General Discussion | 25 | ||
