MATLAB: Average a large number of matricies from .mat files
The discussion focuses on averaging multiple 2x2 matrices stored in .mat files using MATLAB. The user successfully loads the .mat files named data1.mat through data60.mat but encounters issues when attempting to access them using the eval function. The solution provided involves using curly brackets to reference the cell array, specifically using eval(name{1}) instead of eval(name(1)). This method effectively resolves the issue and allows for the desired averaging of the matrices.
  • Familiarity with MATLAB programming language
  • Understanding of .mat file structure and loading
  • Knowledge of matrix operations in MATLAB
  • Experience with cell arrays and indexing in MATLAB
  • Explore MATLAB's mean function for multi-dimensional arrays
  • Learn about cell array manipulation in MATLAB
  • Investigate efficient file handling techniques in MATLAB
  • Study vectorization techniques to optimize MATLAB code performance
MATLAB users, data analysts, and researchers who need to process and analyze large datasets stored in .mat files.
Hoplite
I have a series of large 2x2 matricies, each of which is stored inside a .mat file. These files have the names data1.mat, data2.mat, data3.mat,..., data60.mat. I have sucessfully loaded each of these .mat files.
I want to create a 1x60 array whose entires are the average values of the matrices. i.e:
average(1) = mean(mean(data1));
average(2) = mean(mean(data2));
etc.
If I average the .mat files individually as above, it works, but I want to write a shot code which averages them all. I can make a string containing the names of the .mat files via
names = strseq('data',1:60)
This gives me an array with entries
name(1)=data1
name(2)=data2
etc.
However, when I try to use eval(name(1)) to call the .mat file, it doesn't work. It gives me the message
"? Undefined function or method 'eval' for input arguments of type 'cell'."
I take it that it is not recognising "name(1)" as a reference to the matrix data1. I'm not even sure that it's actually recognising name(1) as the string data1.
It would be great if anyone could explain what I'm doing wrong, or suggest another way to call these .mat files.
Try using eval(name{1})
note the curly brackets after name.
That really works!
Thanks, Matonski.
11K
9K
