How Do You Solve the 2D Ball Bounce Problem with Angle and Velocity Constraints?
  • Thread starter Thread starter Gil-galad
    2d Ball Bounce
The discussion focuses on solving the 2D Ball Bounce Problem, where a ball is thrown at an initial velocity of 10 m/s at an angle between 5° and 45° towards a wall, with specific constraints on bounces. The ball loses 10% of its velocity after each bounce and must return to the original thrower’s position with less than 0.01° error. Participants suggest using kinematic equations to derive an analytical expression for the initial angle α and discuss the potential complexity of the calculations involved.
  • Understanding of kinematic equations in physics
  • Knowledge of projectile motion and angles
  • Familiarity with concepts of reflection and velocity loss
  • Basic grasp of gravity's effect on motion (9.81 m/s²)
  • Explore advanced kinematic equations for projectile motion
  • Study the principles of reflection in physics
  • Learn about energy loss in elastic and inelastic collisions
  • Investigate Lagrangian mechanics for complex motion problems
Physics students, engineers, and anyone interested in solving complex motion problems involving angles and velocity constraints.
Gil-galad
Hello! Since this is my first post I would like to say I am happy that I joined PF and I will try to contribute as much as I can to this great community.
So let's get down to the gist of the problem.
You are standing 4m from a vertical wall and 0.8m from the ground. You have a bouncy ball that you throw with 10m/s initial velocity at some angle [tex]5^{0} \leq \alpha \leq 45^{0}[/tex] from the horizontal towards the ground. The ball bounces from the ground then bounces off the wall losing 10% of its initial velocity after each bounce. The question is to find this initial angle [tex]\; \alpha[/tex]with less than [tex]0.01^0[/tex] of an error, so that the ball returns to the thrower (original position) assuming that the ball bounces off the wall/ground with the same angle as it hits it (incident angle=reflected angle). Assume gravity at 9.81 m/s/s and no friction is involved. The ball does not rotate.
So my question is how do you approach such problem? Is it possible to construct an analytical expression and then perhaps maximize/minimize only with the help of trivial kinematic equations? Or one must use some generalized coordinates and langrangian & hamiltonian mechanics? I would appreciate some guidance.
I pondered quite for some time before my calculations became quite complicated and nearly gave up. I used the trivial kinematic equations for the trajectory of the ball and tried to get an expression involving the initial angle related to the subsequent reflected ones that define the other 2 trajectories but to no avail.
Welcome to PF!
Hello Gil-galad! Welcome to PF! :smile:
(have an alpha: α and a theta: θ and a ≤ :wink:)
So my question is how do you approach such problem? …
(i think it means "losing 10% of its initial speed" :wink:)
Just call the angle θ, and calculate the speed and angle before and after each bounce …
what do you get? :smile:
  • · Replies 21 ·
