Affine transformations problem
  • Thread starter Thread starter springo
    Transformations
The discussion focuses on finding the matrices for two transformations, T1 and T2, in R3, specifically symmetry transformations. T2 is defined as a reflection across the X-axis, represented by the matrix \begin{pmatrix} {1}&{0}&{0}&{0}\\ {0}&{1}&{0}&{0}\\ {0}&{0}&{-1}&{0}\\ {0}&{0}&{0}&{-1} \end{pmatrix}. The transformation T1 involves symmetry with respect to the line defined by x - √3y = 0 and the plane z = 0. The combined transformation T1(T2) results in a rotation around a line, confirmed by the derived matrix \begin{pmatrix} {1}&{0}&{0}&{0}\\ {0}&{\frac{\sqrt{3}}{2}}&{-\frac{1}{2}}&{0}\\ {0}&{-\frac{1}{2}}&{-\frac{\sqrt{3}}{2}}&{0}\\ {0}&{0}&{0}&{1} \end{pmatrix.
  • Understanding of affine transformations in R3
  • Familiarity with matrix representation of transformations
  • Knowledge of symmetry operations in geometry
  • Basic linear algebra concepts, including matrix multiplication
  • Study the properties of affine transformations in R3
  • Learn about matrix multiplication and its geometric interpretations
  • Explore the concept of rotation matrices and their applications
  • Investigate symmetry operations and their effects on geometric figures
Students studying linear algebra, mathematicians interested in geometric transformations, and anyone working with computer graphics or robotics requiring knowledge of affine transformations.
springo
In R3:
T1 symmetry with respect to x -√3y = 0 & z = 0
T2 symmetry with respect to the X axis
Find:
The matrices for T1 and T2, T1(T2) and check that T1(T2) is a rotation around a line.
T2 is:
[tex]\begin{pmatrix}<br /> {1}&{0}&{0}&{0}\\ <br /> {0}&{1}&{0}&{0}\\ <br /> {0}&{0}&{-1}&{0}\\ <br /> {0}&{0}&{0}&{-1}<br /> \end{pmatrix}[/tex]
The line in T1 belongs to z = 0 and the image of (0,0,0) is (0,0,0), therefore the image of (0,0,1) is (0,0,-1).
In the plane z = 0, with the basis {O, (√3/2, 1/2), (1/2, -√3/2)} the transformation's matrix is:
[tex]\begin{pmatrix}<br /> {1}&{0}\\ <br /> {0}&{-1}<br /> \end{pmatrix}[/tex]
So putting this in the canonical basis and all together in one matrix:
[tex]\begin{pmatrix}<br /> {1}&{0}&{0}&{0}\\ <br /> {0}&{\frac{\sqrt{3}}{2}}&{-\frac{1}{2}}&{0}\\ <br /> {0}&{\frac{1}{2}}&{\frac{\sqrt{3}}{2}}&{0}\\ <br /> {0}&{0}&{0}&{-1}<br /> \end{pmatrix}[/tex]
Then for T1(T2) = T2·T1 which yields:
[tex]\begin{pmatrix}<br /> {1}&{0}&{0}&{0}\\ <br /> {0}&{\frac{\sqrt{3}}{2}}&{-\frac{1}{2}}&{0}\\ <br /> {0}&{-\frac{1}{2}}&{-\frac{\sqrt{3}}{2}}&{0}\\ <br /> {0}&{0}&{0}&{1}<br /> \end{pmatrix}[/tex]
I don't know if I'm doing fine so far, and I don't know how to do the end of the problem.
Thanks for your help.
(Gentle) bump :)
Run a few vectors through your matrix, and see if the output vectors are rotated around a line. The line x = sqrt(3)y seems a likely candidate for the line. The endpoint of each input vector should be the same distance away from the line as the endpoint of the output vector, and the angle of rotation of an input/output vector pair should be the same as that of any other input/output pair.
That's the way I would go. Hope that helps.
Mark
