Does a TV need to be protected from the Earth's magnetic field?
The discussion revolves around the impact of the Earth's magnetic field on the operation of a color picture tube in a television. Participants explore whether shielding is necessary for modern TVs, particularly in relation to the functioning of electron beams and their interaction with magnetic fields.
  • Participants consider the historical context of older TVs and their adjustments for magnetic interference. There is a suggestion to calculate the deflection of the electron beam due to the Earth's magnetic field, questioning if the deflection is significant enough to affect image quality.
The discussion is active, with various perspectives being shared. Some participants are exploring theoretical calculations while others are engaging in more playful or experimental suggestions. No consensus has been reached, but there is a clear interest in understanding the implications of magnetic fields on TV performance.
Participants are encouraged to consider the strength and direction of the Earth's magnetic field, as well as the specifics of electron beam dynamics, without definitive conclusions being drawn about the necessity of shielding.
alycel3
You've just learned about the Earth's magnetic field and how a compass works and
you are relaxing in front of the TV. Tired of your show, you think about how the picture tube works in relation to what you have learned. In a typical color picture tube for a TV, the electrons are boiled off of a cathode at the back of the tube and are accelerated through about 20,000 volts towards the picture tube screen. On the screen is a grid of ``color dots'' about 1/100 inch apart. When the electrons hit them, the dots scintillate their appropriate colors producing the color picture. Without taking apart the set, you determine whether the manufacturer needed to shield the color picture tube from the Earth's magnetic field?
Yea, I think that mostly the older tv's have this 'problem', and in that case the tv is adjusted to compensate for the effect.
Try putting your tv upside down. In that case the orientation of the magnetic field is the wrong way, so the picture comes out wrong.
I think the point might be to calculate the deflection of the beam due to the Earth's magnetic field and see if it's as large as 1/100 inch rather than proposing a physical experiment. Just a guess.
No, this is more fun ;)
Look up the strength and direction of the Earth's magnetic field at the altitude of your choice...see if it deflects an electron over a distance of a foot or two enough to make a difference in it's trajectory...F = qv x B, etc...
  • · Replies 32 ·
  • · Replies 30 ·
10K
