Originally Posted by K Sengupta
P is a 8-digit base ten positive integer having the form ABCDEFGH that uses each of the nonzero digits from 1 to 8 exactly once, and satisfies all of these conditions:
(i) AB is divisible by 8.
(ii) BC is divisible by 7.
(iii) CD is divisible by 6.
(iv) DE is divisible by 5.
(v) EF is divisible by 4.
(vi) FG is divisible by 3.
(vii) GH is divisible by 2.
Determine all possible value(s) that P can assume.
Step 1 (list the multiplication table for XY < 90):
AB has to be: 16,24,32,40,48,56,64,72,80,88
BC has to be: 14,21,28,35,42,49,56,63,70,77,84,
CD has to be: 12,18,24,30,36,42,48,54,60,66,72,78,84
DE has to be: 10,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85
EF has to be: 12, 16, 20, 24, 28, 32, 36, 40, 44, 48, 52, 56, 60, 64, 68, 72, 76, 80, 84, 88
FG has to be: 12, 15, 18, 21, 24, 27, 30, 33, 36, 39, 42, 45, 48, 51, 54, 57, 60, 63, 66, 69, 72, 75, 78, 81, 84, 87
GH has to be: 10, 12, 14, 16, 18, 20, 22, 24, 26, 28, 30, 32, 34, 36, 38, 40, 42, 44, 46, 48, 50, 52, 54, 56, 58, 60, 62, 64, 66, 68, 70, 72, 74, 76, 78, 80, 82, 84, 86, 88
Step 2 Now eliminate any numbers that have 9 in them or 0 in them or numbers with the same digit twice:
AB has to be: 16,24,32,48,56,64,72
BC has to be: 14,21,28,35,42,56,63,84,
CD has to be: 12,18,24,36,42,48,54,72,78,84
DE has to be: 15,25,35,45,65,75,85
EF has to be: 12, 16, 24, 28, 32, 36, 48, 52, 56, 64, 68, 72, 76, 84
FG has to be: 12, 15, 18, 21, 24, 27, 36, 42, 45, 48, 51, 54, 57, 63, 72, 75, 78, 81, 84, 87
GH has to be: 12, 14, 16, 18, 24, 26, 28, 32, 34, 36, 38, 42, 46, 48, 52, 54, 56, 58, 62, 64, 68, 72, 74, 76, 78, 82, 84, 86
Step 3:
DE has only endings of 5, so E = 5
Therefore EF is limited to 50 <= EF <= 59
so EF has to be: 52, 56
FG then has to be: 21, 24, 27, 63
GH then has to be: 14, 16, 18, 32, 34, 38, 46, 48, 74, 76
Step 4: Start making connections:
If AB was 16, BC is 63, CD is 36, which can't be possible because of repeating
If AB was 24, BC is 42, so nope
If AB was 32, BC is 21 or 28, then CD is 12,18,or 84. 12 doesn't fit. So try 18 first. DE can then be 85 only. EF is 56, FG is 63. However 3 has shown up already, so try 84. DE is then 45, EF is then 56. Again FG is 63, so doesn't work.
AB = 48, BC = 84, doesn't work
AB = 56 => 63 => 36, doesn't work
64 => 42 => 24 doesn't work.
So AB = 72, so A = 7 B = 2
BC = 21 or 28
72 => 21 => 18 => 85 => 56 => 63 => 34
So the final number is 72185634
