Potential energy equilibrium positions
The discussion focuses on finding equilibrium positions for a particle with potential energy defined by the equation U(x) = x + sin((2 rad/m) x) within the range of 0 to π meters. The first derivative of U(x) was calculated as 1 + 2 cos(2x), which was set to zero to find equilibrium points. The solutions include x = π/3 rad and x = 2π/3 rad, with the latter being identified as another valid solution due to the periodic nature of the cosine function. Stability analysis using the second derivative, -4 sin(2x), indicates that x = π/3 rad corresponds to an unstable equilibrium, as the second derivative is negative.
  • Understanding of calculus, specifically derivatives and their applications in physics.
  • Familiarity with potential energy concepts in classical mechanics.
  • Knowledge of trigonometric functions and their properties, particularly cosine.
  • Ability to solve equations involving trigonometric identities.
  • Study the periodic properties of trigonometric functions, focusing on cosine and its inverse.
  • Learn about stability analysis in potential energy systems using second derivatives.
  • Explore the concept of equilibrium in classical mechanics, including stable and unstable types.
  • Practice solving similar problems involving potential energy functions and their derivatives.
Students studying physics, particularly those focusing on mechanics and potential energy, as well as educators looking for examples of equilibrium analysis in particle systems.
frostking
A particle has potential energy
U(x) = x + sin ((2 rad/m) x)
over the range of x greater or equal to 0 meters and less than or equal to pi meters
Where are the equilibrium positions in this range and for each is it a point of stable or unstable equilibrium?
derv of u(x) set = to 0 and then the second derv of u(x)
I solved derv of u(x) = 1 + 2 cos(2x) then set = to 0
so 2 cos(2x) = -1 divide by 2 and cos(2x) = -1/2
2x = arch cos of (-1/2) = 2pi/3 rad
x = 1 pi/3 rad
I get this part but the answer says that x can = 2pi/3 rad as well and I do not understand why.
To determine if equilibrium is unstable or stable I took the second derv and at x = pi/3 and second derv of - 4 sin(2x) I got less than 0 so a maximum and therefore unstable equilibrium
Can someone please help me understand why I should have known to consider 2pi /3? Thanks for your efforts, Frostking
There are an infinite number of solutions to [itex]\cos(2x) = -1/2[/itex]. You just found one - there's another solution which will give you [itex]2\pi/3[/itex] as the final answer.
Thanks, yes I should have realized I needed to check for other values less than or equal to pi!
  • · Replies 29 ·
