Determine the Volume of the solid ?
  • Thread starter Thread starter rclakmal
    Solid Volume
The volume of the solid S is determined by the surfaces z=10-x² and z=y²+1. The intersection of these surfaces results in the equation x²+y²=9, which describes a circle centered at (0,0) with a radius of 3. To compute the volume, polar coordinates are employed, with r ranging from 0 to 3 and θ from 0 to 2π. The integral to evaluate is (9 - r²) * r dr dθ, confirming the necessity of including the r term in the polar coordinate integration.
  • Understanding of multivariable calculus
  • Familiarity with polar coordinates
  • Knowledge of surface equations and intersections
  • Proficiency in setting up and evaluating double integrals
  • Study the application of polar coordinates in double integrals
  • Learn about surface area and volume calculations in multivariable calculus
  • Explore the method of Lagrange multipliers for constrained optimization
  • Investigate advanced integration techniques, including triple integrals
Students in calculus courses, educators teaching multivariable calculus, and anyone interested in solid geometry and volume calculations.
rclakmal
determine the volume of the solid S which is bounded above by the surface z=10-x^2 and below by the z=Y^2+1;
what i did was first i tried to find the intersecting points of two surfaces .So i equal two functions and i got x^2+y^2=9 which is a circle center (0,0) and radius 3.then i used polar coordinates to evaluate this .
(r goes from 0 to 3 and theta goes from 0 to 2*pi )integrate (9-x^2-y^2)drd@.
am i correct ??or have i mad any kind of error?please explain?
Usually you have the function (of course that needs to be in polar coordinates) not only with dr dtheta, but r dr dtheta, so from what you have done the integral is the function 9r - r^3 with respect to r and then theta. Someone should confirm that though since I haven't looked at this in a while.
ah yr i forgot it thnaks !but am i right up to that point ?about setting the limits of the integral and other process ?
