What's Inside the Mystery Box with AC and DC Circuits?
The discussion revolves around identifying the components inside a mystery box containing circuit elements connected in series, specifically focusing on the behavior of these elements under both direct current (DC) and alternating current (AC) conditions. The subject area includes AC and DC circuits, resistors, inductors, and the application of Ohm's law.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the implications of DC and AC measurements on the circuit elements, questioning the roles of resistors and inductors. There are attempts to calculate resistance and inductance based on observed currents and voltages, with some participants expressing confusion about the calculations involved.
Some participants have provided insights into the behavior of circuit elements under different conditions, while others are seeking clarification on specific calculations related to inductance. There is recognition of the challenges faced in solving the problem, with indications of progress in understanding the underlying concepts.
Participants note the transient behavior of circuit elements in DC conditions and the implications for calculating total resistance and impedance in AC conditions. There is mention of a specific mathematical error affecting the calculation of inductance, highlighting the complexity of the problem.
Dita
Two connections allow contact with two circuit elements in series inside a box, but it is not known whether the circuit elements are R,L, or C. In an attempt to find what is inside the box, you make some measurements with the following results. When a 3.0-V dc power supply is connected across the terminals , there is a direct current of 300 mA in the circuit. When a 3.0-V, 60-Hz source is connected , the current becomes 200 mA.
a) What are the two elements in the box?
b) What are their values of R, L or C?
the answers are one inductor and one resistor, and their values are ~29.65mH and 10 ohms.
Can anyone offer some insight on how you would go about solving this? I'm so lost in trying to solve this problem.
the direct current refers to stable conditions after the transient behavior of the circuit. First off, in DC circuits, capacitors behave like open circuits and inductors behave like short circuits after the transient response.
Therefore, the DC current represents solely the resistive element(s) inside the box, and we know that there is not a capacitor inside the box (else the current would be zero).
Using the ohm's law with the applied voltage and drawn current, we can calculate the total resistance inside the box.
After that calculation, we must find what inductive impedance (+j) must be added to the calculated resistor to draw a sinusoidal current with a peak of 200mA when a sinusoidal voltage with a peak of 3 volts is applied.
Finally, we apply the equation that calculates impedance based on frequency and inductance to find inductance.
Thank you very much for the help. I'm absolutely terrible when it comes to inductance and anything related to alternating current =/
So I understand everything up to this point but I keep getting stuck on calculating the L. I'm getting .0132H for some reason. I'm guessing I'm doing something horribly wrong but I'm setting Vmax as 3V, VR,max as (.2 A * 10 Ohms) and VL as (2*[tex]\pi[/tex])*60L) and plugging all that into Vmax = [tex]\sqrt{Vr^2+VL^2}[/tex]
I know this is wrong but I don't know why and it's driving me nuts...
Can you or anyone else offer some insight? I hate asking for step by step instructions but my back's against the wall.
[tex]|Z|=\sqrt{R^2 +X^2}[/tex]
[tex]X=\omega L[/tex]
[tex]|I|=\frac{|V|}{|Z|}[/tex]
Ok, I was using the correct equations, it was just a stupid mathematical error. Thanks a lot for all the help.
