Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Poisson RP: MLE of "k" Share It Thread Tools Search this Thread image
Old Jun7-09, 08:08 PM                  #1
ACM_acm
ACM_acm is Offline:
P(n,tau) = [ [ (k*tau)^n ] / n! ] * exp(-k*tau)
Parameter k is the process of an unknown non random variable that I want to estimate.
I have determined that k^ML = [1 / (n*tau) ] sigma (xi)
I believe this is correct...
How do I determine if K^ML is biased?
Old Jun7-09, 10:32 PM       Last edited by EnumaElish; Jun8-09 at 01:22 AM..            #2
EnumaElish
EnumaElish's Avatar
EnumaElish is Offline:
Recognitions:
Homework Helper Homework Helper
Re: Poisson RP: MLE of "k"
k^ML is unbiased if E[k^ML] = k, otherwise it is biased.
Hint: since each x is distributed Poisson with mean = k, ∑x is distributed Poisson with mean = Nk, where N is the number of x's.
Old Jun8-09, 07:30 AM                  #3
ACM_acm
ACM_acm is Offline:
Poisson Random Process, Sufficient Statistic
OK - I think I understand you...I would like to rewrite the problem using the LATEX symbology...This is my first time to this website and I would like to learn this program....
My problem is stated as follows...
  • Stationary Poisson Random Process
  • The probability of n events in an interval of time tau is
P(n,tau) = LaTeX Code: \\frac{(k\\tau)}{n!} LaTeX Code: ^{n} eLaTeX Code: ^{-k\\tau}
  • parameter k is an unknown RV that I want to estiamte
  • I will observe x(t) over an interval (0,T)
My questions are as follows...
(1) is LaTeX Code: N , the number of events that occur in the interval (),T), a sufficient statistic, or is it necessary to record the actual event times?
I am not sure what this question is looking for....how can I model this? or think of it? Once I get this part, I will move on to the rest of the problem...
Thanks in advance!
Old Jun8-09, 10:45 AM                  #4
EnumaElish
EnumaElish's Avatar
Recognitions:
Is k a R.V., or is it a deterministic (although unknown) parameter (i.e. constant)?
Old Jun8-09, 10:49 AM                  #5
ACM_acm
ACM_acm is Offline:
k is a is an unknown nonrandom variable.
Based on this....I would say that it is deterministic....
Old Jun8-09, 10:51 AM                  #6
EnumaElish
EnumaElish's Avatar
Recognitions:
In your later post you wrote N is the number of events. I had used N as the sample size (number of x's). Did you mean to write n instead?
Old Jun8-09, 10:55 AM                  #7
ACM_acm
ACM_acm is Offline:
YES - you are correct. Unfortunatly, the write up I have is written very poorly.
Old Jun9-09, 12:58 AM                  #8
EnumaElish
EnumaElish's Avatar
Recognitions:
"I am not sure what this question is looking for....how can I model this? or think of it? Once I get this part, I will move on to the rest of the problem..."
You can start with studying the concept of Sufficient Statistic. See, for example, http://en.wikipedia.org/wiki/Sufficient_statistic
image image
Reply
Tags
estimator, mle, poisson process
Thread Tools
Similar Threads for: Poisson RP: MLE of "k"
Thread Thread Starter Forum Replies Last Post
Learning device, help me expound: on Faraday's choice of "ion", and "unionized" ddd1600 Electrical Engineering 2 Apr14-09 12:13 AM
Difference between "Identical", "Equal", "Equivalent" XxnecroxX Calculus & Beyond 9 Apr11-09 09:14 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
