Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Calculus & Analysis
Reply
image perimeter of an elipse -- exact formula Share It Thread Tools Search this Thread image
Old Jun7-09, 08:28 PM       Last edited by realitybugll; Jun8-09 at 01:56 PM..            #1
realitybugll
realitybugll is Offline:
I found an exact formula for the perimeter of an ellipse in terms of its major and minor axis
a = 1/2(major axis)
b=1/2(minor axis)
my equation for the perimeter of an ellipse:
LaTeX Code: 4{\\frac{\\frac{(a^2+b^2)\\frac{1}{b}\\pi}{4}}{\\frac{2  ({\\sin^{-1}(\\frac{a}{\\sqrt{a^2+b^2}})-45)}}{90-2{(\\sin^{-1}(\\frac{a}{\\sqrt{a^2+b^2}})-45)}}+1}
The perimeter of an ellipse with semi-major axis a and eccentricity e is given by 4aE(pi/2,e), where E is the complete elliptic integral of the second kind. This can be calculated to great precision instantly on any mathematics program like mathematica
I tested it against this formula a couple times:
for a =3, b =1
the formula: 12.808
my formula:12.870
for a=7 b=2
the formula:29.462
my formula:29.499
for a=84 b = 9
the formula:339356
my formula:338.56555
on cabri II plus i drew a proof that shows how i got this -- if u want that tell me.
any insight is greatly appreciated
Old Jun7-09, 08:43 PM       Last edited by dx; Jun7-09 at 08:50 PM..            #2
dx
dx's Avatar
dx is Offline:
Recognitions:
PF Contributor PF Contributor
Homework Helper Homework Helper
Re: perimeter of an elipse -- exact formula
Just try it on a circle, a = b = r, with r = 1. You should get 2pi. What does your formula give?
Old Jun7-09, 10:48 PM                  #3
realitybugll
dx,
yea it gives 2pi, i also simplified it quite a bit.
I also tried it against perimeter of ellipse "calculators" online and got similar results -- the formulas they use have up to 11% margin for error though.
Old Jun7-09, 11:26 PM       Last edited by dx; Jun7-09 at 11:33 PM..            #4
dx
dx's Avatar
dx is Offline:
Recognitions:
Are you sure you didn't just chage it so that it would give the right answer for a circle? (I didn't check your formula btw)
How did you get rid of the sin inverse that you previously had in the numerator? Where are these "11% margin of error" calculators that you mention. Do you have a link? And yes, please show us your proof.
Old Jun7-09, 11:48 PM                  #5
realitybugll
no i did not. And i don't blame you for not checking it; its kind of a pain. The numerator did originally have inverse sin in it. But it simplyfied on my calculator to:
LaTeX Code: {\\frac{\\frac{(a^2+b^2)\\frac{1}{b}\\pi}{4}}
im not sure how it did it but they do equal each other, I checked the previous numerator equation against the new one multiple times.
I found a "perimeter of an ellipse calculator online" that use an approximation formula with 11% margin for error
My formula is not a guess -- the proof is very convincing. I did it on Cabri II plus because its geometric. I can send you the file if you want, you would have to download the trial version though to see it if you don't have it.
Old Jun8-09, 12:05 AM       Last edited by dx; Jun8-09 at 12:16 AM..            #6
dx
dx's Avatar
dx is Offline:
Recognitions:
Well, the thing is, the perimenter of an ellipse involves an elliptic integral, which cannot be expressed in closed form in terms of elementary functions (which you claim to have done).
Also, I find this "11% margin of error" thing odd. It can easily be calculated to much greater precision.
The perimeter of an ellipse with semi-major axis a and eccentricity e is given by 4aE(pi/2,e), where E is the complete elliptic integral of the second kind. This can be calculated to great precision instantly on any mathematics program like mathematica. See this for example:
http://www79.wolframalpha.com/input/?i=4*1*E(pi%2F2%2C0)
Just substitue whatever a and e you want in the above link and check your formula.
Old Jun8-09, 12:22 AM                  #7
realitybugll
sorry i don't know a lot about this stuff.
So my equation uses the 2 radius's of the ellipse to calculate its perimeter
how can i get the eccentricity from the radius's?
so int he equation i put in the largest radius and e?
-- never mind i found what e is in terms of a,b....
Old Jun8-09, 12:27 AM                  #8
dx
dx's Avatar
dx is Offline:
Recognitions:
eccentricity is just e = √(1 - (b/a)2).
Old Jun8-09, 01:08 AM                  #9
Unit
Unit is Offline:
you posted this thread twice , the other place is here.
with your equation, like i explained in that thread also, letting LaTeX Code: a = b = r results in LaTeX Code: \\frac{2 \\pi r}{ \\frac{0}{0} + 1 } , but 0/0 is not supposed to happen?
Old Jun8-09, 01:09 AM       Last edited by realitybugll; Jun8-09 at 01:34 AM..            #10
realitybugll
for a =3, b =1
the link: 12.808
my formula:12.870
for a=7 b=2
the link:29.462
my formula:29.499
for a=84 b = 9
the link:339356
hmm...so i guess my formula is not exact
I'm going to go look back at my proof...
Old Jun8-09, 01:10 AM       Last edited by realitybugll; Jun8-09 at 02:33 AM..            #11
realitybugll
yeah i know, for it to work 0/0 has to equal 0, not be undefined...
Ive read that there are exceptions where 0/0 can equal 0...so maybe this is one of them?
Old Jun8-09, 12:06 PM                  #12
Mute
Mute is Offline:
How are you getting a 0/0?
The "offending" term is
LaTeX Code: \\frac{\\sin^{-1}(\\frac{a}{\\sqrt{a^2+b^2}})-45}{90-(\\sin^{-1}(\\frac{a}{\\sqrt{a^2+b^2}})-45)}
The parentheses on the bottom cover both the arcsin and the 45 deg: it's not 90 - arcsin - 45. Hence, when a = b, the arcsin gives 45 degrees, so the numerator is zero, and the denominator is 90 deg - (45 - 45). So, you've got 0/90 = 0, so in this particular instance the formula gives the correct result.
I doubt the formula given here is exact, since that would seem to imply there's a closed form expression for the complete elliptic function of the second kind. I suppose it's possible the formula is a decent approximation, though.
Old Jun8-09, 02:06 PM       Last edited by realitybugll; Jun8-09 at 02:30 PM..            #13
realitybugll
yeah your right you do get 0/90 -- i had forgot, i assumed unit was correct
the proof for how i got this formula is very convincing so i have faith in it
Also I originally messed up posting the formula, i've now edited it
Old Jun8-09, 02:23 PM                  #14
arildno
arildno is Offline:
Recognitions:
Originally Posted by realitybugll View Post
yeah your right you do get 0/90 -- i had forgot that unit was correct
Well, we do not have that.
Not the least since it has been proven long ago that the elliptic integral can't generally be expressed as a closed expression of elementary functions.
Which you claim to have done..
So, please post the actual proof.
Old Jun8-09, 02:34 PM       Last edited by realitybugll; Jun8-09 at 03:29 PM..            #15
realitybugll
yes, i will
Old Jun8-09, 03:21 PM                  #16
Unit
Unit is Offline:
yup, you're right, my mistake. i wrote it down on paper omitting the brackets.
image image
Reply
Thread Tools
Similar Threads for: perimeter of an elipse -- exact formula
Thread Thread Starter Forum Replies Last Post
elipse Physicsissuef Precalculus Mathematics 24 Apr19-08 05:47 AM
line tangent to an elipse given one point thursdaytbs Introductory Physics 9 Jun30-05 03:43 AM
Best fit to an elipse kepler General Math 0 Jun20-05 01:54 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
