Magnetic field of an infinite layer
The discussion focuses on proving that the magnetic field above an infinite layer with thickness D and current density J is constant regardless of height z. Participants suggest using Ampère's Law for the proof, emphasizing the need to select an appropriate rectangular path for integration. The integration is divided into four parts, with two segments along the y-axis and two along the z-axis, to ensure the magnetic field's independence from z. The symmetry of the problem indicates that the z-component of the magnetic field must be zero, simplifying the integration process.
  • Understanding of Ampère's Law
  • Familiarity with magnetic fields and their properties
  • Knowledge of integration techniques in physics
  • Basic concepts of symmetry in electromagnetic theory
  • Study the application of Ampère's Law in different geometries
  • Explore the concept of magnetic field symmetry in infinite current distributions
  • Learn about the integration of vector fields in physics
  • Investigate the relationship between current density and magnetic fields in various materials
This discussion is beneficial for physics students, electrical engineers, and anyone interested in electromagnetic theory, particularly those studying magnetic fields generated by current-carrying conductors.
Dell
given a n infinite layer, with a thickness of D and a current density of J direction in the diagram (on x-), prove that the magnetic field above the layer is constant irrespective of the height 'z'
http://lh4.ggpht.com/_H4Iz7SmBrbk/Si1JMFGiWEI/AAAAAAAABEE/LVo64TBgsmw/Untitled.jpg
i had a similar problem in electrostatics and what i did was use gauss law, here what i want to do is use amperes law, the problew is finding the correct path to use. i think that it must be a rectangle path therefore my closed integration will be in 4 parts, 2 along the y axis, 2 along the z axis,, i thought of taking a path of length L, at a height Z,
somehow i need to get 0 for the integration of the heights, so that my equation is independent of z
Take any rectangular path enclosing the full thickness of a section of the slab that is in the yz plane.
By symmetry, what can you say about the component of B in the z direction? What does this say about [itex]\int B\cdot ds[/itex] over the two sides of the rectangle in the z direction?
AM
  • · Replies 24 ·
