Earth & moon rotate round center of mass
The discussion revolves around calculating the time it takes for the moon to rotate around the Earth, considering the Earth-moon system's center of mass. The original poster presents a problem involving gravitational forces, reduced mass, and orbital mechanics, aiming to reconcile the calculated rotation period with an expected adjustment of 4 hours due to the system's dynamics.
  • Participants explore various methods, including the use of Kepler's laws for binary systems and the implications of treating the Earth as stationary versus accounting for its mass. Questions arise about the necessity of using reduced mass and the assumptions behind infinite inertial mass.
There is an ongoing exploration of different approaches to the problem, with some participants suggesting alternative methods and questioning the assumptions made in the calculations. While some guidance has been offered regarding the use of Kepler's laws, there is no explicit consensus on the correct approach or solution yet.
Participants note the complexity of the problem due to the interplay between the masses of the Earth and moon and the need to consider their motion relative to the center of mass. The original poster's calculations yield a discrepancy in the expected time adjustment, prompting further inquiry into the assumptions made during the analysis.
Karol
1. Homework Statement
Calculate the time the moon rotates once around the earth, and show that you have to add 4 hours to that since the moon & the Earth rotate around their center of mass. hint: use the reduced mass: [tex]\overline{m}[/tex]=[tex]\frac{m_{1}m_{2}}{m_{1}+m_{2}}[/tex]
mass of moon: m=0.0734E24[kg]
mass of earth: 81 times mass of moon: M=81m
radius of earth: Re=6.37E6[m]
distance centers earth-moon: 60Re
gravity constant: G=6.673E-11
(1) F=[tex]\frac{GMm}{r^{2}}[/tex]
(2) F=[tex]\frac{mV^{2}}{r}[/tex] (3) V=[tex]\frac{2r\pi}{T}[/tex]
xc.m.=[tex]\frac{m_{1}x_{1}+m_{2}x_{2}}{m_{1}+m_{2}}[/tex]
maybe: the momentum in the center of mass coordinate system: (4)[tex]\vec{p_{1}}[/tex]=m1[tex]\vec{V_{1}}[/tex]=[tex]\overline{m}[/tex][tex]\vec{V_{12}}[/tex], while V12 is the relative velocity between them, and [tex]\overline{m}[/tex]=[tex]\frac{m_{1}m_{2}}{m_{1}+m_{2}}[/tex] is the reduced mass.
the revolution time when the Earth is "stuck" in place and the moon rotates only: using equations: (1)=(2), (3): [tex]\Rightarrow[/tex] [tex]\frac{mV^{2}}{60R^{e}}[/tex]=[tex]\frac{81Gm^{2}}{(60R_{e})^{2}}[/tex] [tex]\Rightarrow[/tex] T=2,357,028[sec]=27.28[days], and the relative velocity is: V12=1018.8[m/sec].
the distance of the center of their mass from center of earth: xc.m.=[tex]\frac{60R_{e}m}{82m}[/tex]=4,660,976[m]
now, in the coordinate system of the moving center of gravity, i find the moon's tangential velocity, knowing that the relative velocity V12 is the same in all coordinate systems: according to equation (4) above: V1=[tex]\frac{\overline{m}V_{12}}{m_{1}}[/tex]=1006.3[m/sec]
now, the revolution time of the moon round the distance to center of mass (3): [tex]\frac{2\pi(60R_{e}-x_{c.m.})}{1006.3}[/tex]=2,357,187[sec]
this is only 159[sec] more, not 4 hours!
Have you considered using Kepler's law for a rotating binary system?
[itex]\Omega^2 = \frac{4\pi^2}{P^2} = \frac{G(m_1+m_2)}{R^3 }[/itex]
(P is the period of time it takes for the binary to orbit one another)
We know that: [itex]m_1r_1=m_2r_2[/itex], so R is defined as [itex]r_1+r_2[/itex]. r1 and r2 are the radii from the centre of mass of the two objects to the objects themselves.
I'm not sure it'll work if they asked you to use the reduced mass, but it might work - it's how i'd go about trying to solve it anyway.
Thanks, Faloren, but I only know the 3 Keppler laws for eliptical motion, not this one.
and also this gives a better result: 2 hours difference, but not 4.
did you use reduced mass AND non-infinite Earth mass? I think one makes the other unnecessary.
What is non-infinite mass? give me a clue, but i should use the reduced mass of both, the Earth & moon as given by the formula.
in the first calculation you treated the Earth as being stationary. you treated it as though it had infinite inertial mass. (but not infinite gravitational mass)
I'm not an expert but I'm pretty sure that when you use the reduced mass for the moon you still treat the Earth as though it had infinite inertial mass. that's why its so much easier to use.
I am not that expert either, and i don't expect you to explain to me what are infinite inertial mass & not infinite gravitational mass, but the formula:
[itex]\overline{m}=\frac{m_{1}m_{2}}{m_{1}+m_{2}}[/itex]
makes use of them both.
I think this is not the direction, but using the moving center of mass coordinate system, in which this formula applies to.
by infinite inertial mass I just mean that you treat it as though it were stationary
By infinite mass, that's not entirely true - it's more like you treat the smaller object as having negligible mass, right?
The idea being that if you're working out, say the orbit of the Earth about the Sun, you don't need to know the mass of the Earth because the sun's mass will dwarf it (i.e. as you say, it won't affect the orbit of the sun - the sun is for all intents and purposes stationary - although on an interesting note this is how astronomers detect exo-planets these days, by measuring stars wobbling).
Oh, and inertial mass = gravitational mass, this was one of Einstein's assumptions when developing general relativity i believe - no experiment has yet found a difference between the two.
  • · Replies 25 ·
