What is the induced current in a moving frame near a changing current wire?
  • Thread starter Thread starter Dell
    Faraday Lenz
The discussion revolves around a problem involving an infinite straight wire with a time-varying current described by the equation i=2t. A conducting square frame is positioned near the wire, and the frame is moving away from the wire at a constant velocity. Participants are tasked with determining the induced current in the frame at a specific time, considering the changing magnetic field due to the varying current in the wire.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between the changing current and the resulting magnetic field, questioning how to calculate the magnetic flux through the moving frame. There are discussions about integrating over time versus space, and the implications of the frame's motion on the magnetic field and flux calculations.
Several participants have provided insights and alternative approaches to calculating the magnetic flux and induced current. There is an ongoing exploration of the correct boundaries and expressions for the magnetic field, as well as discussions about the direction of the induced current based on the calculated flux. Some participants express confusion about the units and the implications of the changing current.
Participants note that the problem involves a moving frame and a time-dependent current, which complicates the calculations. There are references to potential issues with sign conventions in the calculations of induced current and electromotive force (emf). The problem statement's clarity is questioned, particularly regarding the direction of the magnetic field.
Dell
in the following question i am given an infinite straight wire with a current changing according to i=2t, next to the wire is a conducting square with a side of a=5cm at t=0 the square is at a distance of b=5cm from the wire and the frame is moving away from the frame at v=2m/s,
the frame has a resistance of R=2 Ω
http://lh6.ggpht.com/_H4Iz7SmBrbk/SjDX68M6InI/AAAAAAAABEg/thgSA-myiaI/Untitled.jpg
what is the induced current in the frame at t=0.5s??
my problem here is that i would usually have a constant B field so i would find the flux, but now my field changes according to R, when R=b+v*t. and my current changes according to t, so can i do one single integral of t??
dΦ=AdB, = a2*[tex]\frac{μ*2t}{2π(b+v*t)}[/tex]dt
but the problem now is that that integral would only take into account the field at the left hand side of the square,
so i thought maybe a double integral
∫dt∫a2*[tex]\frac{μ*2t}{2π(r)}[/tex]dr where r goes from (b+v*t) to (a+b+v*t)
=a2μ/π * ∫tdt∫dr/r
= a2μ/π ∫t*ln([tex]\frac{(a+b+v*t) }{(b+v*t)}[/tex]dt from 0 to 0.5
does this seem okay or am i totally off,
then once i find the flux at t=0.5
dΦ/dt=-I*R
I=-dΦ/(Rdt)
I am confused about the problem statement, i=2t makes little sense because the units don't match. Could you explain this?
every 0.5 second the current gets 1A bigger , i(t=0)=0, i(t=1)=2...
Okay.
To obtain the flux you should not integrate over t. To obtain the flux we need to know dA. As you said yourself the magnetic field at a time t varies with a distance perpendicular to the wire, but not parallel to the wire. Therefore you can express dA=adr, with r the distance away from the wire.
The flux then becomes [itex]\phi_B=\int B a dr[/itex]. You just need to find the correct boundaries and expression for B now.
i tried this, didnt work though
dA=a*dr
B=μI/(2πr)
dΦ = BdA = aμI/(2πr)dr, ---> r=v*t ; dt=vdr
dΦ = aμI/(2vπr)dt ---> I=2*t
dΦ = aμt/(vπr)dt
dΦ/dt=aμt/(vπr) = -ε= -IinducedR
Iinduced=-aμt/(Rvπr) = -aμ/(Rv2π)
where have i gone wrong here?
i know you said not to integrate with 't' but i need to for dΦ/dt
If r=vt, then dr=v dt for constant v, therefore dt=dr/v.
I don't think this approach will be very fruitful however. Could you calculate the magnetic flux at a time t=t_0?
thanks for the help, i got it, onlt thing is my answer has an opposite sign to the correct one, but from what i understand the sign is not that important if you state the direction,,, this is what i wrote,
how will i know what direction the curren flows, i need to know if the flux is increasing or decreasing, and since the current is increasing AND the distance is increasing, (1 increases flux one decreases flux)
A sign difference means that you're going in the opposite direction. You could of course calculate the magnitude of the emf and then explain in what direction it flows. What expression did you find for the flux?
Φ=aμt/π*(ln(a+b+tv)-ln(b+tv))
my final answer came to
I=3.22997*10^-11 A and the answer is meant to be
I=-3.23*10^-11 A
I just ran the numbers myself and your value is correct, however your sign is wrong. The emf is defined as [itex]-\frac{d\phi}{dt}[/itex]. I have a feeling you only calculated [itex]\frac{d\phi}{dt}[/itex] and forgot to put the minus in front. You can see from the flux you calculated that the emf has to be negative as well, because dphi/dt>0. Have you been able to find the direction of the current?
emf=-dΦ/dt = IR
I=-aμ/πR*{ln(a+b+tv)-ln(b+tv)+vt*[1/(a+b+tv)-1/(b+tv)]}
when i plug in the values i get 3.22997*10^-11 A
if you say that the flux increases as t increases, then the current would have to be anti clockwise right??
You can't say that based on the flux alone, you also need to know the direction of the magnetic field. I can't find that in the problem statement though, perhaps it's in the picture which isn't working for me.
o, of course, the current is flowing upwards, therefore the field on the right hand side, where the square is is into the page, and my induced field must be opposite to that,,,
do you see anything wrong with my calculations that i can't get the minus??
Are you using a pocket calculator or something? I copy pasted the formula for the emf you derived (which is the same one I derived) straight into mathematica and plugged in the given quantities. All I can think off is that you forgot a minus somewhere.
