Study on Propeller Spin Rate vs. Wind Angle of Attack: Tips and Techniques
  • Thread starter Thread starter jessiem
    Bit
This discussion focuses on the relationship between propeller spin rate and wind angle of attack for a physics project. Key recommendations include using lightweight materials such as balsa wood or plastic for the propeller, employing a servo motor to adjust the angle of attack, and utilizing a more powerful fan or leaf blower to generate sufficient wind. Additionally, the use of a motion detector for data collection is emphasized, along with the importance of maintaining constant variables during experiments.
  • Understanding of aerodynamics and the principles of lift and drag
  • Familiarity with motion detection technology and data collection methods
  • Basic knowledge of servo motors and their applications
  • Experience with model airplane propeller design and materials
  • Research the properties and applications of balsa wood and plastic in model aircraft
  • Learn about servo motor control and its integration in experimental setups
  • Investigate the use of leaf blowers for generating airflow in experimental physics
  • Explore data visualization techniques for analyzing experimental results
This discussion is beneficial for physics students, hobbyists in aerodynamics, and educators looking to enhance their understanding of experimental design related to propeller dynamics and airflow analysis.
jessiem
Hey guys I need a little help with my physics project
It's a private investigation, and I've decided that my topic would be:
The rate the propeller spins vs. the angle of attack of the wind.
Ive decided to change the variable by changing the angles the flap faces towards the wind (generated by a fan).
I can record the motion by using a motion detector on the computer, thanks to the physics department of out school..
So basically what I need to know is:
what would be the best way to make the propeller (what material)
How would I change (by rotating the flap maybe?) the angle of attack
How can I make it so the wind gernerated by a normal electric fan is strong enough to make the propeller spin
AND any useful suggestions..? :confused:
Thanks!
Use a light plastic. You ought to be able to buy such a thing at a novelty store or, if you can't find such, go to a hobby store and ask about propellors for model airplanes. Get the largest one you can. Now, remove the propellors (carefully!) from the hub and devise a way of attaching them to a hub at different angles.
Hi there! Your project sounds really interesting and I'm glad to hear that you have access to resources from your school's physics department. Here are some tips and techniques that may help you with your study on propeller spin rate vs. wind angle of attack:
1. Material for the propeller: The best material to use for your propeller would be lightweight and durable, such as balsa wood or plastic. These materials are commonly used in model airplanes and are ideal for your project.
2. Changing the angle of attack: One way to change the angle of attack is by using a flap or a rudder attached to the propeller. You can use a servo motor to control the movement of the flap and change the angle of attack accordingly. Another option is to manually adjust the angle of attack by hand, but this may not be as precise.
3. Generating strong wind: Electric fans may not generate strong enough wind to spin the propeller at a desired rate. You can try using a more powerful fan or even a leaf blower to generate stronger wind. You can also experiment with different distances between the fan and the propeller to find the optimal distance for maximum wind force.
4. Data collection: As you mentioned, using a motion detector is a great way to record the motion of the propeller. Make sure to calibrate the detector before each trial and to keep all other variables constant (such as distance from the fan, wind speed, etc.).
5. Suggestions: Here are some additional suggestions that may help you with your project:
- Try to keep all other variables constant, such as wind speed, distance from the fan, and the weight of the propeller.
- Conduct multiple trials for each angle of attack to ensure accurate data.
- Consider plotting your data on a graph to see the relationship between propeller spin rate and wind angle of attack.
- You can also try using different types of propellers to see if there is any difference in their spin rate at various wind angles.
I hope these tips and techniques will help you with your project. Good luck!
  • · Replies 69 ·
18K
  • · Replies 39 ·
45K
