Interesting thing about archers hitting the target |
Jun13-09, 11:23 AM
#1
Дьявол is
Offline:
Hello, again!
I got one very interesting question.
We got three archers, and the probability of the ones to hit the target is:
A 1, A 2, A 3.
What if the task is to find the probability that the target will be hit at least from one archer.
So at least one archer to hit the target.
Is it P(A 1 U A 2 U A 3) = A 1 + A 2 +A 3 ?
Or  , where  is opposite of A?
Or maybe, both are valid?
Thanks in advance.
Jun13-09, 11:47 AM
#2
HallsofIvy is
Offline:
Re: Interesting thing about archers hitting the target
Originally Posted by Дьявол
Hello, again!
A1, A2, A3.
Is it P(A1 U A2 U A3) = A1 + A2 +A3 ?
No. This is wrong.  and that extends to 3 events:   .
Yes, this is correct.
Thanks in advance.
Jun13-09, 11:53 AM
#3
Дьявол is
Offline:
Thanks for the post, HallsofIvy.
In this case, the shootings of the archers are independent cases. So that's why we do not need
since  . That's why I said independent cases.
But what if P(A 1)=0.8, P(A 2)=0.9, P(A 3)=0.75
In that case the sum
This is strange.
Jun13-09, 12:55 PM
#4
mXSCNT is
Offline:
The fact that two cases A and B are independent doesn't mean P(A n B) = 0. It means that P(A n B) = P(A)P(B).
Jun13-09, 02:00 PM
#5
Дьявол is
Offline:
If two cases are independent, that means that they do not have something in common, right? So A n B = 0, right?
Jun13-09, 03:52 PM
#6
statdad is
Offline:
Recognitions:
No,
if the two sets are disjoint , which is not the same as independent.
Jun13-09, 05:36 PM
#7
Tibarn is
Offline:
Actually, that would mean that they're not independent. Two events are independent if the occurrence of one does not influence the occurrence of the other, i.e. P(A|B) = P(A). If  , then P(A|B) = 0, so the events are not independent.
With regards to the original question, it would be easiest to take the probability that every archer misses and subtract it from one.
Jun14-09, 04:36 AM
#8
Дьявол is
Offline:
Thanks for the replies.
@Tibarn, in this case the occurrence of one does not influence the occurrence of the other.
out of there
and
The cases are independent if the occurrence of one does not influence the occurrence of the other. So, if two cases are independent, then P(A/B)=P(A). Out of there P(A n B)=P(A)*P(B)
Now, let's get back to the task. I think I mean, disjoint. So cases A,B are disjoint.
P(A U B)=P(A) + P(B) - P(A n B)
In this case  because the cases:
I - the 1st archer will hit the target
II - the 2nd archer will hit the target
DO NOT have something in common.
Is this true?
Are those cases disjoint??
Jun14-09, 12:30 PM
#9
CRGreathouse is
Offline:
Recognitions:
You're saying that if one archer hits the target the other one always misses?
Jun14-09, 03:37 PM
#10
Дьявол is
Offline:
Jun14-09, 09:37 PM
#11
Tibarn is
Offline:
Think about this intuitively. If A and B are disjoint, then event A and event B cannot occur simultaneously. So, if A is the first archer hitting the target and B is the second archer hitting the target,  means that both archers cannot simultaneously hit the target. If we know that A hit the target, then it would follow that B missed the target, so the events are not independent (unless A or B always misses).
If both archers take one shot, then we have four possible events:
1. Both miss
2. Archer A hits, B misses
3. Archer A misses, B hits
4. Both hit.
In this case,  is case 4, where both archers hit. If you're going to do probability by cases, it's important that you get all of them.
Jun15-09, 09:53 AM
#12
Дьявол is
Offline:
Now, I understood. Thank you very much for the help.
Regards.
Jun15-09, 11:29 AM
#13
HallsofIvy is
Offline:
You may be confusing "mutually exclusive" with "independent". "Independent" means what happens in one case does not affect what happens in the other-  or, equivalently, P(A|B)= P(A). "Mutually exclusive" means  so that P(A|B)= 0. Not at all the same thing!
Jun15-09, 11:56 AM
#14
Дьявол is
Offline:
Yes, you're right. I did a little research, and find out that the events in this case aren't exclusive, but they are independent. Because if they are exclusive P(A) or P(B) will be equal 0 so that P(A n B)=0.
