Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > General Math
Reply
image Quick Algebra Problem Share It Thread Tools Search this Thread image
Old Jun14-09, 05:45 AM                  #1
jazduck
jazduck is Offline:
I have an equation which I ended up with as t^2 + t = 5.1
How do I then solve for t (without just plugging it into solve on the calculator)?
Old Jun14-09, 06:14 AM                  #2
Cyosis
Cyosis is Offline:
Recognitions:
Homework Helper Homework Helper
Re: Quick Algebra Problem
This should be in the homework section. You can solve it by using the ABC-formula.
Old Jun14-09, 06:32 AM                  #3
jazduck
jazduck is Offline:
Cyosis - The question is not homework so I put it in general math. The actual question i'm trying is one on the initial velocity of an object required to catch another object released a second before it over a 50m displacement. Not that hard if I make my calculator solve it, just making a mess of the algebra because I havn't done it in 8 years.
Anyway will look up the ABC rule.
Old Jun14-09, 09:56 AM                  #4
Cyosis
Cyosis is Offline:
Recognitions:
The solution to an equation of the form LaTeX Code: ax^2+bx+c=0 is given by LaTeX Code: x=\\frac{-b \\pm \\sqrt{b^2-4ac}}{2a} . To make use of this formula you will have to write LaTeX Code: t^2+t=5.1 as LaTeX Code: t^2+t-5.1=0 .
Old Jun14-09, 10:08 AM                  #5
HallsofIvy
PF Mentor
HallsofIvy is Offline:
Alternatively, you could "complete the square".
For any number, a,
LaTeX Code: (t- a)^2= t^2- 2at+ a^2
You have LaTeX Code: t^2+ t= 5.1 which will match the first two terms of that if 2at= t or a= 1/2. In that case LaTeX Code: a^2= 1/4 so adding 1/4 to both sides of the equation: LaTeX Code: t^2+ t+ 1/4= 5.1+ 1/4= 5.1+ .25= 5.35
Now that the left side is a "perfect square" you have LaTeX Code: (t+ 1/2)^2= 5.35 and you can solve that by taking the square root of both sides (remembering that the result can be either positive or negative).
image image
Reply
Thread Tools
Similar Threads for: Quick Algebra Problem
Thread Thread Starter Forum Replies Last Post
Quick Linear Algebra Proof squaremeplz Calculus & Beyond 1 Mar2-09 11:17 PM
Quick Algebra question Larrytsai Precalculus Mathematics 8 Apr25-08 07:19 AM
Quick Linear Algebra Question courtrigrad Calculus & Beyond 7 Oct12-06 08:22 PM
quick abstract algebra Q tamser0630 Introductory Physics 0 May9-04 01:27 PM
Quick algebra questions. physicszman Introductory Physics 3 Feb6-04 01:18 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
