Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > General Math
Reply
image Rotation angle clockwise or anticlockwise? Share It Thread Tools Search this Thread image
Old Jun14-09, 06:51 AM                  #1
whitenight541
whitenight541 is Offline:
Hi all,
I want to implement rays emitted from diffraction by a wedge. So I have a wedge with 2 faces ,a common edge and an incident ray. I have the tangent and normal to each face. I calculated the base of the diffracted rays so that it lies in one of the faces. I want to rotate this ray several times about the edge until I reach the other face.
I have the rotation matrix. The problem is I can't determine whether my rotation angle is clockwise or anticlockwise. I can rotate in one direction only (since it is a wedge and rays shouldn't go inside the walls).
Is there any vector operation I can use to determine this?
Old Jun14-09, 08:32 AM                  #2
D H
D H is Offline:
Recognitions:
Homework Helper Homework Helper
Re: Rotation angle clockwise or anticlockwise?
Clockwise or counterclockwise with respect to what? You need a reference direction to say whether some rotational motion is clockwise or counterclockwise. Imagine you have a transparent clock hanging like a chandelier. Viewed from one side the hands appear to move clockwise, but from the other side they appear to move counterclockwise.
Old Jun14-09, 10:48 AM                  #3
junglebeast
junglebeast is Offline:
Originally Posted by whitenight541 View Post
Hi all,
A positive rotation rotates from (1,0) to (0,1). Usually (1,0) is defined as right, and (0,1) can either be up or down depending on if you are drawing a typical graph (where it is up) or considering pixels on the screen (where it is down). If you just have a rotation matrix and you don't know whether or not it represents positive or negative rotation, use it to transform the vector (1,0) and see where it goes.
Old Jun14-09, 11:15 AM                  #4
whitenight541
Well with respect to the faces of the wedge. Denote one face as faceO and the other as faceN. I want to partition the angle from faceO to faceN to emit several rays through it. Ofcourse this angle is the outside of the wedge not inside it (so it can be > 180).
For example let a wedge has an inner angle of 90. So this means that i want to emit rays in the external 270 degrees starting from faceO to faceN. The problem is if I started at faceO I don't know in what direction should I rotate in order to reach faceN (through the external 270 degrees)
I have the rotation matrix with the angle as a variable so I have to specify the angle. if positive then counterclockwise if negative then clockwise.
Old Jun14-09, 01:58 PM                  #5
HallsofIvy
PF Mentor
HallsofIvy is Offline:
what is your rotation matrix? A rotation about angle LaTeX Code: \\theta can be written as the matrix
LaTeX Code: \\begin{bmatrix}cos(\\theta) & -sin(\\theta) \\\\ sin(\\theta) & cos(\\theta)\\end{bmatrix}
Because LaTeX Code: sin(-\\theta)= -sin(\\theta) , if the number LaTeX Code: -sin(\\theta) in the "upper right" of your matrix is negative, this is a rotation through a positive angle, an anti-clockwise rotation. If it is positive, it is a rotation through a negative angle, a clockwise rotation.
Old Jun15-09, 12:47 AM                  #6
whitenight541
No, this is a rotation about an arbitrary axis so the rotation matrix is more complicated than this.
It is found here http://en.wikipedia.org/wiki/Rotation_matrix
image image
Reply
Thread Tools
Similar Threads for: Rotation angle clockwise or anticlockwise?
Thread Thread Starter Forum Replies Last Post
Is the rotation angle in Minkowski's diagram real or imaginary? gene1721 Topology & Geometry 6 May14-09 02:38 PM
Clockwise or counterclockwise rotation about a fulcrum invadertak Introductory Physics 1 May12-09 02:23 PM
Help with determining Angle of Rotation for a Conic, please. popsquare General Math 2 Dec10-07 10:33 AM
rotation angle ehrenfest Calculus & Beyond 3 Sep28-07 11:59 PM
Why not anticlockwise? Qyamat General Astronomy 5 Dec27-04 08:51 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
