Thermal equilibrium + heavier mass
The discussion centers on the influence of mass on the final temperature of two objects in thermal equilibrium. In the example provided, a 4 kg copper block at 0 degrees Celsius and a 1 kg aluminum block at 100 degrees Celsius reach a final temperature of approximately 36 degrees Celsius. This outcome is attributed to the total heat capacity of the objects, where the heavier copper block, despite having a lower specific heat capacity, possesses a greater total heat capacity due to its mass. The distinction between specific heat as an intensive property and heat capacity as an extensive property is crucial in understanding this phenomenon.
  • Understanding of thermal equilibrium principles
  • Knowledge of specific heat capacity and heat capacity
  • Familiarity with intensive and extensive properties
  • Basic thermodynamics concepts
  • Research the calculations for total heat capacity in thermal systems
  • Explore the relationship between mass and temperature change in thermal equilibrium
  • Study the differences between intensive and extensive properties in thermodynamics
  • Learn about specific heat capacity values for various materials
Students of physics, engineers, and anyone interested in thermodynamics and heat transfer principles.
ariana0923
Why is it that the object with the heavier mass influences the final temperature (once the two objects in contact have achieved thermal equilibrium)?
For ex. a copper block (4 kg) at 0 degrees and an aluminum block (1 kg) at 100 degrees...in this case, the final temp ends up lower (36 ish degrees), I'm guessing because the copper (heavier block) was colder, so it influenced the final temp. But is there a deeper reason besides the fact that its heavier? (In this case, you can't say specific heat capacity right? since Al has the higher capacity)
Science news on Phys.org
It is precisely because of heat capacity. Which specific is J/kg/K and heat capacity is J/K
So although Al has the specific capicity, the object has a lower total heat capacity (not sure on the nomenclature here) because there is less of it.
If there were only 2kg of copper the Al block would have a higher total heat capacity.
The difference is because becase specific heat is an intensive property and heat capacity is extensive.
  • · Replies 23 ·
23K
10K
