Fourier Series Representation of a Square Wave using only cosine terms.
The discussion revolves around the Fourier Series Representation (FSR) of a square wave using only cosine terms. The original poster is preparing for an exam and is uncertain about their approach to the problem, which involves drawing a square wave and computing its trigonometric and exponential FSRs.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to draw a square wave and compute its FSR, expressing confusion about the need for cosine terms and the implications of amplitude. Other participants question the assumptions made regarding the wave's symmetry and the presence of negative components. There are discussions about the definitions of even and odd functions in relation to the square wave.
Participants are exploring various interpretations of the problem, particularly regarding the characteristics of the square wave and its representation in terms of cosine functions. Some guidance has been offered regarding the nature of even and odd functions, but there is no explicit consensus on the correct approach yet.
There is mention of homework constraints, such as the requirement for the FSR to consist solely of cosine terms and the absence of a DC component. Participants are also navigating the implications of amplitude in the context of square waves and their Fourier representations.
Dint
Hello, I am attempting a past exam paper in preparation for an upcoming exam. The past exam papers do not come with answers and I'm a little unsure as to whether I'm doing all of the questions correctly and would like some feedback if I'm going wrong somewhere.
Any help is greatly appreciated :)
Here are the questions:
Draw a square wave of amplitude 1 and period 1 second whose trigonometric Fourier Series Representation consists of only cosine terms and has no DC component.
Now, I assume they want the FSR to be made up of only cosine terms, there is another question on another past exam that asks for the same thing but in sine terms. A normal square wave that is:
1 for 0<x<.5
0 for -.5<x<0
Consists of only sine terms when you do the FSR (when I did it). It also makes sense because it looks like a sine wave in that it rises at the origin.
2. The attempt at a solution
However, to make it consist of only cosine terms, I'm not quite sure how to draw this, this is what I came up with.
http://img34.imageshack.us/img34/2/squarewave.jpg
I did this because I figured it resembles what a cosine wave looks like, in that it peaks at the origin. (I know it's a square wave so it doesn't really peak, but I'm picturing a cosine wave representing the signal in the box)
PART B - 1. Homework Statement
The next part of the problem asks:
For the signal in part A, compute the trigonometrical FSR.
then
Compute the exponential FSR directly from the trigonometric FSR.
[tex]a_{0} = \frac{1}{T} \int\limits_{f_{0}}^{f_{0}+T} f(t) dt[/tex]
[tex]a_{n} = \frac{2}{T} \int\limits_{f_{0}}^{f_{0}+T} f(t) cos\left(\frac{2{\pi}nt}{T}\right) dt[/tex]
[tex]b_{n} = \frac{2}{T} \int\limits_{f_{0}}^{f_{0}+T} f(t) sin\left(\frac{2{\pi}nt}{T}\right) dt[/tex]
I've also been told that for the exponential FSR:
[tex]c_{0} = a_{0}[/tex]
[tex]c_{n} = {\frac{1}{2}}\left(a_{n} - jb_{n}\right)[/tex]
[tex]c_{-n} = {\frac{1}{2}}\left(a_{n} + jb_{n}\right)[/tex]
[tex]a_{0} = \frac{1}{2}[/tex]
By inspection I can see that the average value of one period of the square wave is going to be 0.5.
[tex]a_{n} = \frac{2}{1} \int\limits_{-{\frac{1}{4}}}^{{\frac{1}{4}}} cos\left(\frac{2{\pi}nt}{1}\right) dt[/tex]
Now when I do this integral, I get:
[tex]\frac{1}{{\pi}n} \left[ sin\left(\frac{{\pi}n}{2}\right) - sin\left(-\frac{{\pi}n}{2}\right)\right][/tex]
I'm kinda stuck here. This answer does not give zero, I need the FSR to contain no sine terms, and this answer for my an term does give sine terms...
Any ideas?
Thanks a lot for taking the time to read this.
This is also my first time using latex, so if I stuffed anything up I'm sorry.
Dint said:
I did this because I figured it resembles what a sin wave looks like, in that it peaks at the origin. (I know it's a square wave so it doesn't really peak, but I'm picturing a sine wave representing the signal in the box)
A sine wave is 0 at the origin, sin(0)=0.
Your latex is good.
Hint: If you want the cosine series to be zero you should find yourself an f(t) which is odd.
In the drawing that I did, was I wrong to say the amplitude of that is 1? Is the amplitude actually .5? If it's a square wave as I drew it, does that not mean that It's pk-pk amplitude is 1?
I'm getting really confused with the amplitude now. I've always understood amplitudes using sin and cosine waves but I've never worked out amplitudes with a vertical shift.
In your drawing their are no negative peaks, so there is no ambiguity. The peak to peak amplitude is the same as half peak to peak amplitude in this case. You're correct that the amplitude is 1.
hi ENB242 guy, to begin with, what you are doing is wrong. I have done it and comparing what i have done to yours, I am wondering why you don't have the -ve part of the signal?? Also your initial assumption is wrong as well.
can you clarify what you mean? do you mean there should be a negative component as well in the cos wave. that makes sense. i don't get why there is no negative part there. would the amplitudes be 1 and -1 respectively?
Well to put it blunty, yes there should be a -ve and +ve part in the one period. This would mean having amplitudes of -1 and 1 respectively.
Hey,
EVEN --> all cosine terms, bn = 0
ODD --> all sine terms, a0 = 0 and an = 0
So I am assuming one would have to draw an even square wave for all cos terms and an odd square wave for all sine terms.
I've figured out this problem. What I was actually getting confused with was that when it asked for no cosine/sin terms, it was actually referring to an/bn respectively.
My confusion came when I integrated sin and got a cos term, thinking this meant that there were cosine terms. When really this was just the sin term (bn).
Anyway, it's all cleared up and it makes sense to me now.
thanks that explains a lot. just a question with the drawing. if it had a negative component going down to -1 at t = .5 second would it still be an even function? would it still reflect across the x-axis or wouldn it reflect across both.. therefore making it an odd function.. i think I am confusing myself unnecessarily..
An even function is when f(x) = f(-x)
In other words, it is symmetrical about the Y-axis (if you flip it over the Y axis, it is identical.
An odd function is when -f(x) = f(-x)
In other words when the function is symmetrical about the X-axis, once flipped about the Y-axis.
Hope this helped.
Yeah I'm not really sure of your question, I just re-read it and I don't know if I really answered it.
Draw your function on a page, if you fold it so the positive axis flips onto the negative axis and they perfectly line up, the function is even :P
That's probably the easiest way I can explain it. Otherwise, just check if f(x) = f(-x)
ha ahh I am so going to do that.. thanks a lot. yeah i was just trying to visualise the question above with a negative component.. but the folding thing just confirmed what i already had. thanks a lot mate.. good luck for 242
yeah any type.. good luck
guys what about the Fourier transform of s(t) * thatoddsymbol (t)
where s((t) = pike 1 (t)
sorry for horrible use of english there
i get that it will be a square wave of width 1 from 0 to 1 convolving with a ?? i don't get that part. any ideas?
that's delta...
When you find the Fourier transform of the convolution of two functions... eg.
[tex]s(t) * \delta(t)[/tex]
The answer is the multiplication of each functions Fourier transform.
The Fourier transform of a delta function (that funny symbol), is 1. So it's actually just the Fourier transform of s(t).
Correct me if I'm wrong, but I'm pretty positive.
Dint said:
that's delta...
[tex]s(t) * a(t)[/tex]
The answer is the multiplication of each Fourier transform.
Where a(t) is the delta function (that funny symbol), the Fourier transform of a delta symbol is 1. So it's actually just the Fourier traansform of s(t).
Yeah that sounds about right.
Jacobs section is going to be harder than Eds, in order to do well on Jacobs we need to know the formulas for each modulation method...
Then the last question of each exam question I just can't do. :<
I'm not expecting to do well to be honest. After the effort I have put in for ENB240 I ran out of steam for this one. I have done well in the Assignments and Lab, hopefully that helps pull me through.
im hoping that it will be the same as the last exam papers.. both of them are almost identical.. and there quite straight forward albeit with some parts ha.. you guys know more than me so don't worry
  • · Replies 16 ·
