How big would a solar power cell need to be
A solar power cell needs to be approximately 1.68 m² to power a 1 Amp load at 240 Volts, equating to a 240-watt output. This calculation is based on the formula Watts = Amps x Volts. The efficiency of standard solar cells is around 14.3%, while advanced triple-junction solar cells, such as those from Emcore, achieve efficiencies of 27.5%. Relevant solar panel specifications include dimensions of 1600mm x 1050mm x 40mm and a weight of 19.5 kg for a 240-watt panel.
  • Understanding of basic electrical concepts, specifically Watts, Amps, and Volts.
  • Familiarity with solar panel specifications and efficiency metrics.
  • Knowledge of photovoltaic (PV) technology and its applications.
  • Awareness of solar insolation and its impact on solar energy generation.
  • Research solar panel efficiency ratings, focusing on triple-junction solar cells.
  • Explore solar energy calculations for different load requirements.
  • Investigate solar panel installation best practices and sizing guidelines.
  • Learn about solar insolation data and its implications for energy production.
Engineers, solar energy enthusiasts, and anyone involved in designing or optimizing solar power systems will benefit from this discussion.
Starwatcher16
How big would a solar power cell need to be...to power a 0.5 A load (240v)? How about 1 A?2? 10? 50?
Just curious.
Watts = Amps x Volts. So for 1 Amp at 240 Volts that's a 240 watt solar cell. A google search brings up some 240 watt solar cells.
Size of Module (mm) : 1600*1050*40 mm
Weight Per piece (KG) : 19.5 Kg
http://www.ecplaza.net/product/182178_978109/240_watt_solar_panel.html
HP240 1580mm x 1068mm x 40mm 20kg
http://www.dako.co.za/monocrystalline_solar_90-240W.html
That's about 1.68 m2 per 1 amp at 240 volts. To get the other sizes just multiply.
So you say that a 1.68 m2 pv solar cell area can produce 240 watts, or 143 watts per m2. The available insolation at high noon at sea level is about 1000 watts per m2, so this implies about 14.3% efficiency. Here is a triple-junction solar pv cell that Emcore claims has 27.5% efficiency:
http://www.emcore.com/assets/photovoltaics/ATJ_datasheet_2009.11.03.pdf
  • · Replies 22 ·
  • · Replies 29 ·
  • · Replies 38 ·
  • · Replies 25 ·
