How do i calculate magnetic coils output volts ?
The discussion revolves around calculating the output voltage of a magnetic generator designed with neodymium magnets and coils. Participants explore the configuration of the generator, including the arrangement of magnets and coils, and the implications for voltage generation based on various parameters.
  • One participant describes a setup with 12 neodymium magnets and 12 coils, asking for the expected voltage output.
  • Another participant inquires about the type of alternator and the mounting of the magnets, suggesting that the radius of the magnets is critical for coil placement.
  • Further details are provided about the coil dimensions and spacing, with one participant suggesting the potential addition of iron to improve efficiency.
  • A crude estimate of voltage output is calculated based on magnetic field strength, area, and frequency, yielding an initial estimate of approximately 4 volts RMS per turn.
  • Another participant questions whether the total output voltage can be calculated by multiplying the voltage per turn by the number of turns in each coil, leading to a proposed output of 3127 volts RMS.
  • Concerns are raised about the efficiency of coupling all turns of the coil to the magnetic field, suggesting that distance from the magnet pole may affect output.
  • Participants discuss the resistance of the wire used in the coils and its implications for the overall design.
  • Two participants seek advice on sourcing neodymium magnets in Malaysia, indicating a practical interest in the materials needed for the project.
There is no consensus on the exact voltage output, as participants provide differing estimates and raise concerns about the efficiency of the design. The discussion includes multiple viewpoints on the effectiveness of the coil configuration and the potential need for iron to enhance performance.
Participants express uncertainty regarding the coupling efficiency of the coils and the impact of coil thickness and distance from the magnets on voltage output. The calculations presented depend on various assumptions about the magnetic field and coil design.
smart45
i am planning to make a magnetic generator & i have a question :
if i provide a disk with 12 numbers of neodymium (1x1”x1”cylinder) (n48) magnets around it ,
moving by motor clock wise at 1500 rpm ,
( magnet specification: Br: 13.80- 14.20 KG, Hcb: > = 10.5 Koe, Hcj: > = 11 KOe )
the magnets facing 12 Coils , each coil (3”x 2”) with 782 winding turns (copper awg 15),
each coil inductance = 8.685 mH & each coil resistance = 1.051 ohms .
so how many volts can be gain from the output of the coils ?
Is this an air-core alternator, or is there any iron in it? How are you mounting the magnets-are they facing along the z-axis in cylindrical coordinates (r,theta,z)? What is the radius of the magnets from the axis of the rotor? Do you plan to have coils on both sides of the magnets, or only one side? I think ithe radius has to be at least 2" x 12/2 pi = 4" to get the coils in. Are your coils rectangular or trapezoidal? I think you will be generating a 1500 RPM x 6 poles /60 = 150 Hz. Do you plan to rectify it?
dear Bob,
thank you very much for your quick reply.
My answers:
A- 12 coils at stator (on circle shape) facing 12 magnets at one side of the round rotor.
(this is for now but later I shall make another 12 coils also facing the other side of the rotor).
B- each coil cylindrical 3”x 2”.
C- between each coil to another 1.1”.
D- Coils with 6mm hall in the middle of the 3” round side.
(I have left a hall because the N48 magnets are very strong, But if you advise to pot iron
in the middle then I shall do ).
E- 12 magnets are distributed along the circle of the rotor (round disk).
F- each magnet 1”roud face would be facing exactly the middle of the 3” round face coil .
G- radius of the magnets from the axis of the rotor = 8”
H- radius of the coils from the axis of the stator = 8”
Looks good. So you are starting with an iron-free alternator, and perhaps at a later time adding some iron inside or behind the coils? At 150 Hz you might get some eddy curents in iron, so ferrite would be a better choice.
So the question now how many volts can be gain from the output of the coils ?
Verrry crude estimate:
Bpeak = 1 tesla
Area = 5 x 10-4 m2 (area of magnet pole)
w= 2 pi f = 2 pi 150Hz = 942 radians per sec (at 1500 RPM)
N= 1 turn
Vrms = 0.707 x Bpeak x Area x w x N = 0.33 rms volts per turn (open circuit).
Coils should be very close to pole tips.
[Added edit] I forgot to multiply by number of coils (=12) so the answer is
Vrms = 12 x 0.33 = ~ 4 volts rms per turn at 1500 RPM. So if you can get 50 turns on each coil, the output is 4 x 50 = 200 volts rms.
Dear Bob,
Every coil has = 782 turns ( number of layers = 23 X 34 turns per layer ).
Does that mean 4 volts rms X 782 turns = 3127 volts rms ?
You are correct. 4 volts per turn x 782 = 3127 volts, provided the coil thickness is small compared to the magnet size and magnet separation. Coil turns that are more than say one inch from the magnet pole will not couple much. My handbook shows 15 Ga. wire has a spacing of about 16 turns per inch (for enamel coated wire), so the cross section of your coil is 23/16 = 1.43" by 34/16 = 2.1". I do not believe you will couple efficiently to all of the turns unless you have iron (laminated) or ferrite in them. 15 Ga. wire has a resistance of 3.2 ohms per 1000 ft, which with your resistance measurement of 1.051 ohms/3.2 ohms per 1000' = 500 ft per coil, or 7.7" per turn. Your coils will couple inductively, so the inductance will be more than 12 x 8.7 mH.
where can i get neodymium (N48) in Malaysia...Please help?
I have purchased neodymium magnets (cylindrical 3/4" dia by 3/4" long) on eBay with good results. Try them.
Bob S
