Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > General Math
Reply
image Statistic deviation. Share It Thread Tools Search this Thread image
Old Jun24-09, 03:11 PM                  #1
icystrike
icystrike is Online:
I went for a lecture and the lecturer said that the square of the difference between the x sub i and the mean is the take precaution of the negative value. This has been bugging me , i was wondering why dont they just take absolute because there is a difference between :
LaTeX Code: \\sqrt{\\frac{\\sum(x-\\mu)^2}{f}} andLaTeX Code: \\frac{\\sum \\left|(x-\\mu)\\right|}{f}
Old Jun24-09, 05:07 PM                  #2
statdad
statdad is Offline:
Recognitions:
Homework Helper Homework Helper
Re: Statistic deviation.
Yes, there is a difference, as
LaTeX Code: <BR>\\sqrt{\\sum(x-\\mu)^2} \\ne \\sum |x - \\mu |<BR>
There is actually quite a history about whether a measure based on
LaTeX Code: <BR>\\sqrt{\\frac{\\sum (x-\\mu)^2 }{f}}<BR>
or
LaTeX Code: <BR>\\sqrt{\\frac{\\sum |x-\\mu|}{f}}<BR>
should be used. Basically, the measure based on the sum of squared deviations won out because, statistically, when it is assumed that the data are drawn from a normal distribution (equivalently, when it is assumed the random noise is Gaussian).
Old Jun25-09, 02:49 AM                  #3
icystrike
Thanks for your help
Random noise, i got to check this out !
Old Jun25-09, 07:40 AM                  #4
boboYO
boboYO is Offline:
heh, i remember my stats lecturer said that too.
an analogy can be drawn with why we take the squares of the sides (pythagoras) to work out the hypotenuse and not the absolute value.
Old Jun25-09, 08:47 AM                  #5
daviddoria
daviddoria is Offline:
The squared distance is also used because it is continuous, where the absolute distance function has a discontinuity. This is a big problem in optimization.
Old Jun25-09, 09:54 PM                  #6
statdad
statdad is Offline:
Recognitions:
Not really the case in statistics - the median, median deviation, and other procedures use the absolute value.
Old Jun26-09, 06:12 AM                  #7
HallsofIvy
PF Mentor
HallsofIvy is Offline:
The absolute distance function does not have a derivative at a point. There is no discontinuity.
Old Jun26-09, 06:14 AM                  #8
HallsofIvy
PF Mentor
or
When you sum the absolute values, you should not have a square root.
There is a third used occasionally:
LaTeX Code: \\frac{max |x-\\mu|}{f}
The end of your last sentence seems to be missing!
Old Jun26-09, 08:07 AM                  #9
statdad
statdad is Offline:
Recognitions:
Halls, i wish i had your proof-reading skills. Thanks for catching my missed comment.
You are also correct that the absolute value expression has no derivative, but again, for statistics, I'd add that really isn't a problem.
Why did I miss the unneeded square root? Let me know when you figure it out, because I can't.
image image
Reply
Thread Tools
Similar Threads for: Statistic deviation.
Thread Thread Starter Forum Replies Last Post
Standard deviation versus absolute mean deviation Twinbee Set Theory, Logic, Probability, Statistics 2 Jun6-09 02:24 PM
Testing a Statistic without standard deviation? KatieLynn Calculus & Beyond 1 Nov30-08 08:08 PM
Mean Absolute Deviation/Standard Deviation Ratio kimberley Set Theory, Logic, Probability, Statistics 4 Nov29-07 11:12 AM
Statistic Help!!! lopram General Math 1 Nov21-06 01:50 PM
Statistic help pls PrudensOptimus Set Theory, Logic, Probability, Statistics 2 Apr3-05 05:49 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
