What Is the Probability a Moviegoer Waits Less Than 20 Minutes?
  • Thread starter Thread starter yitriana
    Movie Time
The discussion focuses on calculating the probability that a moviegoer waits less than 20 minutes, given average waiting times of 10 minutes for tickets and 5 minutes for popcorn. Participants express uncertainty about the appropriate statistical functions to model the waiting times, noting that the average alone is insufficient for probability calculations. They suggest that the waiting times might be modeled using exponential distributions, but emphasize the need for standard deviations to proceed. The complexity arises from the requirement to sum two independent exponential variables with different parameters. Overall, the consensus is that more information is needed to accurately solve the problem.
yitriana
The manager of a movie theater determines that the average time movie-goers wait in line to buy a ticker for this week's film is 10 minutes, and avg time to wait to buy popcorn is 5 minutes. Assuming waiting times are independent, find probability that moviegoer waits less than 20 minutes before taking his or her seat.
Waiting times for ticket and popcorn can probably be modeled as functions, but I don't know which specific functions. I don't know how to approach the problem
I don't think there's enough information to answer the question. You indeed would seem to need to know the distribution functions, not just the averages. Are you supposed to assume Gaussian distributions maybe?
I agree with berkeman that there isn't enough information given. Assuming that the waiting times are normally distributed, it seems to me that you need to know the standard deviations of the two waiting times in order to calculate any probabilities.
The "easy" part: waiting times are usually modeled with the exponential distribution ("E.D."). Question: what is the relationship between the mean and the variance of an E.D.?
The tough part: you have a random variable that is the sum of two exponential variates with distinct parameters. (The wiki page in the link above tells you what to do if their parameters were identical, that is, if lambda1 = lambda2 were the case.) Are you expected to derive this distribution yourself?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
