Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > General Math
Reply
image Is there a rule of thumb for small angle approximation? Share It Thread Tools Search this Thread image
Old Jun26-09, 12:06 AM                  #1
Starwatcher16
Starwatcher16 is Offline:
When you are not given an acceptable level of error in a problem, is there any rule of thumb I should use for how large Theta can be before I stop using the small angle approximation(Sin Theta=Theta) ?
Old Jun26-09, 12:24 AM                  #2
rock.freak667
rock.freak667 is Offline:
Recognitions:
Homework Helper Homework Helper
Re: Is there a rule of thumb for small angle approximation?
According to my text book it says (to 3sf, in radians)
LaTeX Code: -0.105<\\theta<0.105
Old Jun26-09, 12:32 AM                  #3
Hurkyl
PF Mentor
Hurkyl's Avatar
Hurkyl is Offline:
Decide for yourself what level of error is appropriate. Then use your calculus to determine if that approximation is good enough!
The Taylor remainder theorem is a systematic way to bound the error on an approximation.
However, when theta is small, the Taylor series for sin is an alternating series whose terms are strictly decreasing -- so an easier method is to use what you know about alternating series to estimate the error.
Old Jun26-09, 12:34 AM                  #4
protonchain
protonchain is Offline:
In general if you're doing really simple and very very approximate calculations then anything less than 0.5 would probably be just fine.
Truly though, the best way to look is to see a graph of Sin x / x. Analyze this and look at the regions where it is 0.95 - 1 for example, and you can then grasp where you can begin to approximate.
About x = 0.55 is where Sin x / x = 0.95. Obviously as x goes to 0, the value increases towards 1.
I hope that helped or at least made you get up and get your graphing calculator :P
image image
Reply
Thread Tools
Similar Threads for: Is there a rule of thumb for small angle approximation?
Thread Thread Starter Forum Replies Last Post
small signal approximation diode model Bolterx101 Engineering, Comp Sci, & Technology 1 Apr19-09 08:21 AM
maxwell equations rule of thumb? bman!! Advanced Physics 1 Apr1-08 04:03 PM
Approximation and Simpson's Rule ada0713 Calculus & Beyond 6 Jan31-08 09:52 PM
Small angle approximation. quasar987 Advanced Physics 6 Jan20-07 10:50 AM
Taylor rule of thumb?? Azael Calculus & Beyond 7 Jan10-06 03:45 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
