Is a single point in R compact?
  • Thread starter Thread starter fraggle
    Compact Point
The discussion revolves around the compactness of a single point in the real numbers, R. Participants explore the implications of definitions and theorems related to compact sets, particularly in the context of topology.
  • Conceptual clarification, Assumption checking, Mixed
  • Some participants assert that a single point is compact due to its closed and bounded nature, referencing the Heine-Borel theorem. Others express uncertainty about the terminology used, questioning whether it is appropriate to refer to a point as compact or to clarify that it is a singleton set that is compact.
The discussion is active, with participants providing different perspectives on the definition of compactness and its application to single points. There is a mix of agreement and humor regarding the rigor of arguments presented, and some participants suggest that using certain theorems may overlook deeper understanding.
There is mention of potential conventions or preferences among educators regarding the use of specific theorems to demonstrate compactness, indicating a possible divide in pedagogical approaches.
fraggle
It seems obvious since every open cover of a single point in R can clearly have a finite subcover.
However, I have a little uncertainty (i.e possible convention that says otherwise?) so just wanted to check before using it in a proof.
thanks
A subset of R is compact if it is closed and bounded (Heine Borel). A set consisting of a single point is certainly bounded and closed and therefore compact
That's it. No more work needed
I would probably fail anyone using this argument on principle
Technical point: it makes no sense to talk about a point being compact. What you mean is that a set containing a single point (a "singleton" set) is compact. That's true in any topology, not just R or even just in a metric space. Given any open cover for {a}, there exist at least one set in the cover that contains a and that set alone is a "finite subcover".
And I would say you would be in error to do so.
What would you say to this:
Let [tex]p[/tex] be the point. We know that there is some compact space [tex]K[/tex]. The map defined by [tex]f(x) = p[/tex] for all [tex]x \in K[/tex] is continuous. The continuous image of a compact set is compact. Therefore [tex]\{p\}[/tex] is compact. QED
I was mostly being humorous. However, I know a lot of teachers that specifically don't want people to use Heine-Borel to prove the compactness of sets because it misses the point (which is to demonstrate your knowledge of what compactness means).
Oh, surely you can find an even more complicated proof than that!
17K
9K
