Thread Closed
Q: Torque-speed? Motors and rotating plinths - Please help!
Share Thread
Jun29-09, 11:50 AM   #1
Dear engineering gurus,
I was wondering if some of you might be able to help me out with my project (2 part question):
I'm basically trying to make a rotating plinth (like those used
in jewelry displays - except i need it to bear a weight of 1kg.
(Most ready-made plinths wont take anywhere near that so i imagine id have to build my own.
Now i've come across a small motor (MM54) that has the following info for its specs:
Constant Volts: 6 - 9
Speed RPM: 8900 - 16200
Torque (g-cm): 174 - 236
Stall torque (g-cm): 980 - 1800
My first question is - would anyone know if this motor is powerful enough to take the weight of 1kg and still function?
(Am i right to be choosing a motor that has a high torque speed?) Is there another motor that someone could recommend that would suit my purpose?
Second question - As i need to bring this down to about 1 RPM, can anyone recommend a gearbox that will allow me to do this?
(Is this even possible with the motor i'm suggesting?)
Apologies if my questions seem a little inept - ive never done anything quite like this before. And i really really appreciate any help or suggestions...
Thanks!
PhysOrg.com engineering news on PhysOrg.com
>> Multiview 3-D photography made simple
>> Giant 3-D printed bugs shed light on insect anatomy
>> A microphone that listens with light
Jun29-09, 01:29 PM   #2
Go to www.ebay.com and search for "gear motor". I got over 1000 hits. Some are around 1 RPM.
Jun29-09, 02:49 PM   #3
Hi Bob,
Thanks for that.
I found 2 other motors that (i believe) seem more appropriate:
The one is: 12V, 1 RPM, 65 Stall-torque (in-oz)
The other is: 12V, 2 RPM, 31 Stall-torque
If i wanted to have a bit more control in the RPM, should i be getting
the second one that is 2RPM and then get a dimmer-switch type thing to adjust it?
Would that work?
And also, what is the relation between my 1kg weight requirement and the 'stall-torque'?
Is 31 stall-torque alot? does it equate to a weight capacity? Could i go for maybe something that has 7RPM but then only 16 stall-torque?
Thanks again.
Jun29-09, 03:44 PM   #4
1 kg is the just the vertical mass the unit has to support. The required torque is probably less than 0.5 inch oz (or maybe 10 gram-cm). If you get a dc one, you can adjust the speed by reducing the input voltage.
Jun29-09, 04:11 PM   #5
Ah ok,
So the 12V motor with 31 stall torque is more than 60x what i need to rotate the 1kg?
Great.
Thanks again for the help Bob.
Thread Closed
Tags
motor, plinth, rpm, torque, weight
Similar discussions for: Q: Torque-speed? Motors and rotating plinths - Please help!
Thread Forum Replies
Torque about the axle of a rotating disk Introductory Physics Homework 3
how to determine the torque of a rotating disc? Mechanical Engineering 6
Torque on a rotating charge due to a uniform magnetic field Advanced Physics Homework 5
The torque of rotating disc Engineering, Comp Sci, & Technology Homework 1
Dual speed motors Electrical Engineering 0
